Matrice 600 Firmware V1.0.0.80
1345 4 2017-3-16
dmyers
Hi,
I recently upgraded my Matrice 600 firmware to V1.0.0.80.  After that upgrade it seems there is slightly better flight performance which I'm happy with.  That being said now when I try to use the variety of flight planning apps that I have been experimenting with (for waypoint flying) the apps no longer recognize when the remote control is in F-Mode (intelligent flight mode).  Now Litchi, DJI Ground Station Pro, and Autopilot all aren't capable of flying waypoints because the apps don't recognize when the vehicle is in F-Mode.  The DJI Go App does however recognize when the drone is in intelligent flight mode but I'm guessing this is because of an update to the app on Feb 12, 2017.  Has anyone else experienced this with the M600?  I can always downgrade a version however I do think the vehicle is more reliable as a whole with the new firmware.
2017-3-16
SkySight Aerial
Flight distance : 3312018 ft
With the stand alone A3 you need to use P mode. Not sure if this is the same on the m600. F mode was changed to Sport mode.
2017-3-17
ricci2
Flight distance : 61158 ft
Hi,
I have not experienced any of the issues with GSP or autopilot, Sometimes the firmware has not installed properly so the thing to do is downgrade and power cycle the craft, controller and clean the iPad/tablet of all running app then turn on, upgrade again and power cycle to see if that brings you back to a normal state. I have done this once or twice when there is an issue. If you have done this and all is not well PM DJI Jamie, he normally has some good suggestions and answers.
ricci
2017-3-17
HELOUAV
When I upgraded the only issue I had is calibrating compass in the vertical position. Still having that problem anyone have a  solution for that? Horizontal calibrates fine.
2017-3-21
ricci2
HELOUAV Posted at 2017-3-21 06:24
Hi,
Yes I had this problem but I found if I went in the garden away from electrical  cables and magnetic fields I could calibrate it properly.
Hope that helps for you.
ricci
2017-3-21
