Maxxpsoft
Flight distance : 380594 ft
Google had this on Magnetic Interference
If it's constant and won't go away like your pic that shows compass stuck at 0
Go to your Sensor settings in the app to see what it's showing for the compass.
If there are numbers there, you should be able to calibrate the compass but if it shows zero, the compass is not connected. Possibly the connector to the mainboard is loose or there is a broken wire in the landing gear. Have to open her up. Yes I been there cause my compas was getting the stuck error so I replaced it by replacing legs and all with compass from amazon
When you calibrate get away from everything including concrete. No watch, phone, or even keys with that auto unlock feature or an apple watch I've read. Hold level and rotate 360 degrees but go past where lights change color. Face down and rotate again till lights change. Gotta love this compass dance and where did they come up with this????????? |
