NRG2000
Flight distance : 541772 ft
Japan
I also had a look at the contents of the UpgradeLog.txt which is located on the controllers micro SD card.
------------- check_version -----------------
ID = 0xd ,current version [0.1.1.1] <--> [0.1.1.1], Need upgrade !!
ID = 0xe ,current version [5.2.3.2] <--> [5.2.3.2], Need upgrade !!
kMsgUpgrade e
upgrade 0x0E ,result 0x0, success !!
ID = 0xe ,current version [5.2.3.2] <--> [5.11.13.0], Need upgrade !!
kMsgUpgrade e
[20170218 14:26:54] ------------- check_version -----------------
[20170218 14:26:57] ID = 0xe ,request version failed !
[20170218 14:26:57] upgrade 0x0E ,result 0x0, success !!
[20170218 14:27:18] ------------- check_version -----------------
[20170218 14:27:21] ID = 0xe ,request version failed !
[20170218 14:27:21] upgrade 0x0E ,result 0x0, success !!
[20170218 14:37:11] ------------- check_version -----------------
[20170218 14:37:14] ID = 0xe ,request version failed !
[20170218 14:37:14] upgrade 0x0E ,result 0x0, success !!
[20170218 16:10:39] ------------- check_version -----------------
[20170218 16:10:42] ID = 0xe ,request version failed !
[20170218 16:10:42] upgrade 0x0E ,result 0x0, success !!
[20170218 16:19:04] ------------- check_version -----------------
[20170218 16:19:07] ID = 0xe ,request version failed !
[20170218 16:19:07] upgrade 0x0E ,result 0x0, success !!
[20170218 16:21:11] ------------- check_version -----------------
[20170218 16:21:14] ID = 0xe ,request version failed !
[20170218 16:21:14] upgrade 0x0E ,result 0x0, success !!
[20170218 16:22:34] ------------- check_version -----------------
[20170218 16:22:37] ID = 0xe ,request version failed !
[20170218 16:22:37] upgrade 0x0E ,result 0x0, success !!
[20170218 16:28:09] ------------- check_version -----------------
[20170218 16:28:12] ID = 0xe ,request version failed !
[20170218 16:28:12] upgrade 0x0E ,result 0x0, success !!
[20170218 16:32:48] ------------- check_version -----------------
[20170218 16:32:51] ID = 0xe ,request version failed !
[20170218 16:32:51] upgrade 0x0E ,result 0x0, success !!
[20170218 17:16:15] ------------- check_version -----------------
[20170218 17:16:15] ID = 0xd ,current version [0.1.3.0] <--> [0.1.3.0]
[20170218 17:16:15] Need upgrade !!
[20170218 17:16:18] ID = 0xe ,request version failed !
[20170218 17:16:18] START UPGRADE ,devid d
[20170218 17:16:18] START UPGRADE ,devid e
[20170218 17:16:18] upgrade 0x0E ,result 0x0, success !!
[20170218 17:19:57] ------------- check_version -----------------
[20170218 17:20:00] ID = 0xe ,request version failed !
[20170218 17:20:00] upgrade 0x0E ,result 0x0, success !!
[20170218 17:22:30] ------------- check_version -----------------
[20170218 17:22:33] ID = 0xe ,request version failed !
[20170218 17:22:33] upgrade 0x0E ,result 0x0, success !!
[20170218 17:27:36] ------------- check_version -----------------
[20170218 17:27:39] ID = 0xe ,request version failed !
[20170218 17:27:39] upgrade 0x0E ,result 0x0, success !!
[20170218 17:42:24] ------------- check_version -----------------
[20170218 17:42:27] ID = 0xe ,request version failed !
[20170218 17:42:27] upgrade 0x0E ,result 0x0, success !!
[20170218 19:53:57] ------------- check_version -----------------
[20170218 19:54:00] ID = 0xe ,request version failed !
[20170218 19:54:00] upgrade 0x0E ,result 0x0, success !!
[20170218 20:39:35] ------------- check_version -----------------
[20170218 20:39:38] ID = 0xe ,request version failed !
[20170218 20:39:38] upgrade 0x0E ,result 0x0, success !!
[20170218 22:15:45] ------------- check_version -----------------
[20170218 22:15:48] ID = 0xe ,request version failed !
[20170218 22:15:48] upgrade 0x0E ,result 0x0, success !!
[20170218 22:20:35] ------------- check_version -----------------
[20170218 22:20:38] ID = 0xe ,request version failed !
[20170218 22:20:38] upgrade 0x0E ,result 0x0, success !!
[20170218 22:20:53] ------------- check_version -----------------
[20170218 22:20:53] ID = 0xd ,current version [0.1.3.0] <--> [0.1.3.0]
[20170218 22:20:53] Need upgrade !!
[20170218 22:20:56] ID = 0xe ,request version failed !
[20170218 22:20:56] START UPGRADE ,devid d
[20170218 22:20:56] START UPGRADE ,devid e
[20170218 22:20:56] upgrade 0x0E ,result 0x0, success !!
[20170218 22:24:43] ------------- check_version -----------------
[20170218 22:24:46] ID = 0xe ,request version failed !
[20170218 22:24:46] upgrade 0x0E ,result 0x0, success !!
[20170218 22:45:53] ------------- check_version -----------------
[20170218 22:45:56] ID = 0xe ,request version failed !
[20170218 22:45:56] upgrade 0x0E ,result 0x0, success !!
[20170218 22:59:23] ------------- check_version -----------------
[20170218 22:59:23] ID = 0xd ,current version [0.1.3.0] <--> [0.1.1.1]
[20170218 22:59:23] Need upgrade !!
[20170218 22:59:26] ID = 0xe ,request version failed !
[20170218 22:59:26] START UPGRADE ,devid d
[20170218 22:59:26] START UPGRADE ,devid e
[20170218 22:59:26] upgrade 0x0E ,result 0x0, success !!
ID = 0xe ,current version [0.0.0.0] <--> request version failed !
[20170218 23:54:14] Parse file failed ,result 0x01
[20170218 23:54:14] Upgrade failed ,result 0x1
[20170218 23:56:41] ------------- check_version -----------------
[20170218 23:56:41] ID = 0xd ,current version [0.1.3.0] <--> [0.1.3.0]
[20170218 23:56:41] Need upgrade !!
[20170218 23:56:44] ID = 0xe ,request version failed !
[20170218 23:56:44] START UPGRADE ,devid d
[20170218 23:56:44] START UPGRADE ,devid e
[20170218 23:56:44] Upgrade failed ,result 0x1
[20170219 00:03:25] ------------- check_version -----------------
[20170219 00:03:28] ID = 0xe ,request version failed !
[20170219 00:03:28] upgrade 0x0E ,result 0x0, success !!
[20170219 07:42:40] ------------- check_version -----------------
[20170219 07:42:43] ID = 0xe ,request version failed !
[20170219 07:42:43] upgrade 0x0E ,result 0x0, success !!
[20170219 07:43:08] ------------- check_version -----------------
[20170219 07:43:11] ID = 0xe ,request version failed !
[20170219 07:43:11] upgrade 0x0E ,result 0x0, success !!
[20170219 20:51:57] ------------- check_version -----------------
[20170219 20:52:00] ID = 0xe ,request version failed !
[20170219 20:52:00] upgrade 0x0E ,result 0x0, success !!
[20170219 21:02:09] ------------- check_version -----------------
[20170219 21:02:12] ID = 0xe ,request version failed !
[20170219 21:02:12] upgrade 0x0E ,result 0x0, success !!
[20170220 08:09:46] ------------- check_version -----------------
[20170220 08:09:49] ID = 0xe ,request version failed !
[20170220 08:09:49] upgrade 0x0E ,result 0x0, success !!
[20170220 08:14:11] ------------- check_version -----------------
[20170220 08:14:14] ID = 0xe ,request version failed !
[20170220 08:14:14] upgrade 0x0E ,result 0x0, success !!
[20170220 08:15:20] ------------- check_version -----------------
[20170220 08:15:20] ID = 0xd ,current version [0.1.3.0] <--> [0.1.1.1]
[20170220 08:15:20] Need upgrade !!
[20170220 08:15:23] ID = 0xe ,request version failed !
[20170220 08:15:23] START UPGRADE ,devid d
[20170220 08:15:23] START UPGRADE ,devid e
[20170220 08:15:23] upgrade 0x0E ,result 0x0, success !!
ID = 0xd ,current version [0.1.1.1] <--> [0.1.3.0], Need upgrade !!
ID = 0xe ,current version [0.1.1.1] <--> request version failed !
[20170220 12:16:06] ------------- check_version -----------------
[20170220 12:16:09] ID = 0xe ,request version failed !
[20170220 12:16:09] upgrade 0x0E ,result 0x0, success !!
[20170220 12:27:41] ------------- check_version -----------------
[20170220 12:27:44] ID = 0xe ,request version failed !
[20170220 12:27:44] upgrade 0x0E ,result 0x0, success !!
[20170220 12:32:10] ------------- check_version -----------------
[20170220 12:32:13] ID = 0xe ,request version failed !
[20170220 12:32:13] upgrade 0x0E ,result 0x0, success !!
[20170220 16:07:08] ------------- check_version -----------------
[20170220 16:07:11] ID = 0xe ,request version failed !
[20170220 16:07:11] upgrade 0x0E ,result 0x0, success !!
[20170222 16:37:38] ------------- check_version -----------------
[20170222 16:37:41] ID = 0xe ,request version failed !
[20170222 16:37:41] upgrade 0x0E ,result 0x0, success !!
[20170222 20:48:55] ------------- check_version -----------------
[20170222 20:48:58] ID = 0xe ,request version failed !
[20170222 20:48:58] upgrade 0x0E ,result 0x0, success !!
[20170222 20:54:12] ------------- check_version -----------------
[20170222 20:54:15] ID = 0xe ,request version failed !
[20170222 20:54:15] upgrade 0x0E ,result 0x0, success !!
It appears that at least some checks are failing, which might be a symptom of a larger issue but thought it might be worth sharing the information with you never the less. |
