blackcrusader
Flight distance : 689774 ft
Taiwan
Nigel_ Posted at 2017-3-21 17:55
Looks like it was setting off home to the correct house but then the log ends.
Only odd things I can see are that it doesn't set off flying straight, for some reason it flies a little sideways, crab like, and also the ultrasonic sensors had been occasionally seeing the ground just below the aircraft even when it was up above 100 meters. Bad ultrasonic readings can cause the motors to power off in which case it would be in the top of one of the trees on the way home in a straight line from the last point recorded, probably almost at the last point otherwise the log would have been longer.
Yes I downloaded the KSV file and tracked his flight on google earth. I think he should do the same thing as he looks to have flown from his home. Flying over a forest, a bird strike perhaps?
