John Smith
sailingman62 Posted at 2017-3-24 09:23
Problem solved. I didnt realize there is a slight difference between DJI props and aftermarket Phantom props. one has a slightly raised black/silver center and the other is flatter. there was a mix going on.
Thanks everyone.
@"...slightly raised black/silver center..."
Ummm...you aren't speaking of the old 2-piece props from the phantom 2 are you?
Those props are the normal white plastic, but the threaded area are metal inserts physically colored silver and black.
This differs from the P3 props which are 100% plastic and the tops are simply painted silver or black.
Now while I admittedly cannot find any documentation to back this up (and I really would like to see it if it exists), from everything I've read it seems to be the general consensus that DJI advises against 2-piece propellers being used on the e310 motors.
