fans6381fdf7
Hi, I've read the description in the firmware details:
'Ronin-M Push Mode allows the tilt and pan axes to be adjusted directly by hand while the Ronin-M is turned on. This function can be enabled in the DJI Assistant app or PC/MAC Assistant.
Do not adjust the gimbal by hand too frequently when Push Mode is enabled, or else the motors may overheat and enter Overheating Protection Mode, at which point a manual restart is required.
This feature is available with Ronin-M IMU firmware v1.4, GCU firmware v1.2'
But what actually is the practical use of 'push mode'? What is it's intended use?
Thanks!
