battery
zeus48
when i turn on the battery i get a constant beeping sound
will not stop
2017-3-26
Mark The Droner
Flight distance : 2917 ft
The battery is inserted in the AC?
2017-3-26
zeus48
Mark The Droner Posted at 2017-3-26 07:46
yes it is and both battery are full happened when i was updating to 1.8
2017-3-26
zeus48
2017-3-26
digdat
Flight distance : 11896378 ft
is the RC on? is one of the sticks pushed in direction and not neutral in the middle?
2017-3-26
zeus48
rc is on all sticks are in the middle
2017-3-26
Mark The Droner
So what you mean to say is when you turn your aircraft on, it beeps constantly.  So apparently this has nothing to do with your battery.
Does the AC boot up normally?
What do the lights do exactly?  Please be very specific.
2017-3-26
zeus48
yes drone boots up normally as always then starts with a loud beeping sound
r/c on    battery charged    green light on side that it is connected to each other
no blinking lights on bottom of drone
props shake a tiny bit
2017-3-26
DJI Natalia
Flight distance : 318 ft
Have you tried to update the aircraft again?
When turn them on and connect to the mobile device, run dji go app, any notification on the screen?
2017-3-26
fanse4a99990
Here is your answer to fix it......
2017-3-27
Mark The Droner
So did that solve your problem?
2017-3-27
RicardoGray
Flight distance : 4356421 ft
zeus48 Posted at 2017-3-26 10:13
Sounds like the upgrade maybe didn't fully finish for whatever reason. I had the same problem once while upgrading a standard......loud solid beeping. I put it in another room and let it go, after about 20 minutes it finally went quiet. All was good. Never got an explanation what the loud beep meant, very annoying though. Let it go, don't give up, and I'll bet it will be ok.
2017-3-27
Phantomski
Flight distance : 14869882 ft
Remove the .bin file from the SD card? What does your DJI GO report as firmware version?
2017-3-27
