deleted by user
611 2 2017-3-26
tomato
Flight distance : 366194 ft
deleted by user
2017-3-26
JanN_H
Try resetting "standard action" in Settings/Apps/DJI GO4 if there is one set. And try to set the USB-Mode to PTP in the popup, if it comes up.
Best regards
Jan
2017-3-30
Damacone
Flight distance : 358622 ft
I had a similar problem with an Xperiz Z5 tablet.
So.. assuming it's not your cable, try this:
- Enable the 'developer menu' on your device
- Connect the controller to the device
- Go into the developer menu and look for the 'Select USB configuration' option
- Click this option and change it to any other option but 'charging'
- Change it back to 'MTP'
- Try going into the DJI Go4 app - you should be able to click 'Enter Device' now.
This fixed it for me - unfortunately I can't remember where I first saw this workaround to give credit.
2017-3-30
