All my vieos look like this, photos too. Zoom in on the textures of the ground and trees and it's got this weird swirly-paint pattern look to it. Like a high res vincent gogh painting.
I've tried resetting the camera settings and switching between NTSC and PAL.
The Mavic needs good light to really shine. Using negative sharpness values in lower light conditions will cause this. AFAICT negative sharpening is only useful in bright light. Hope this helps.
Hm, that certainly does not look normal.
1) Check focus, is Autofocus enabled?
2) Are all the style values at 0?
3) Are you shooting in JPG? The dji compression algorithm for JPG has some severe problems --> shoot in RAW
Focus is NOT the issue. These are not jpegs. they are vidoe stills. Please understand that there is a weird texture done to the details that almost swirls it and blends everything.
Take a look at these grabs that are zoomed in:
