Litchi and Mavic Pro
4846 21 2017-3-29
usere7a04e8b35
I have seen a couple of posts about problems with the Litchi App and the Mavic. Right on their Facebook page there's a little warning about problems with the Mavic. Does anyone have any updates on the status of this problem? I have a bunch of flying that I want to do in the next couple of days and the enhanced waypoint mode would be very useful.
2017-3-29
DroneFlying
Flight distance : 10774613 ft
I don't believe that waypoint missions are affected, but in any case it's the latest Mavic firmware (v01.03.0500) that broke Litchi, so one option is to downgrade to the prior firmware version (v01.03.0400).
2017-3-29
81SFORLIFE
Flight distance : 313281 ft
I use Litchi a good bit. I've done regular flying around FPV, Waypoints, 360 Panorama shots, and orbits. Those are the 4 main modes I use.
2017-3-29
usere7a04e8b35
Thanks for the feedback.
2017-3-30
The Rev
Flight distance : 1256837 ft
They have disabled the affected functions in the latest update until DJI release new Firmware
2017-3-30
fans1383ca65
Flight distance : 181532 ft
I can' even use Litchi anymore. Waypoints are not accurate, gimbal does not even point to assigned POI and occasionally the mavic rotates 360 when there are no rotation assigned. Prior to firmware update, Litchi always was flawless. I've calibrated IMU, Compass, installed/reinstalled Litchi. I no longer use it until hopefully new DJI firmware is released.
2017-3-31
fans06b77ccc
Flight distance : 1905381 ft
fans1383ca65 Posted at 2017-3-31 14:20
Maybe downgrade to the previous FW while still available? (.04)Better do it soon. They've been updating about every month now, and only keeping the latest and the one previous accessible on dji assist.
Not sure why anyone would assume that DJI is going to change something that will help Litchi work in the next FW.  If they change something and it  restores full Litchi functionality, the change wouldnt specifically be to help Litchi or Litchi users. I'm sure they would rather see Litchi and other 3rd party apps simply  fly away never to be seen again.
2017-3-31
Ex Machina
Flight distance : 1806362 ft
fans06b77ccc Posted at 2017-3-31 16:22
Not sure why anyone would assume that DJI is going to change something that will help Litchi work in the next FW.  I'm sure they would rather see Litchi and other 3rd party apps simply  fly away never to be seen again.
If that were true, why bother publishing an API?
2017-3-31
fans06b77ccc
Ex Machina Posted at 2017-3-31 16:24
Fair point. I guess we will be able to better judge their willingness to help  3rd party app developers and their users  by any future FW changes that will put Litchi back on track. Hope they fix it because Litchi can be a very useful tool.
2017-3-31
Ex Machina
fans06b77ccc Posted at 2017-3-31 16:37
I hope so, too. Haven't used Litchi yet but it's on my list.
2017-3-31
fans2e9aa3da
Flight distance : 7159 ft
Litchi recently updated app (3/21) to fix bugs with new firmware.
2017-3-31
Watty2000
Flight distance : 1074301 ft
fans2e9aa3da Posted at 2017-3-31 17:35
Not true. The latest version of Litchi advises against using Track, Focus and VR modes saying they're all unusable with the latest FW.
2017-3-31
Mojito
I always thought of waypoint  an app I can tap on my map create points altitudes  angle of camera and send it on its way automatic. But all the waypoint youtube shows you having to run the points and record them.  Is there an app I can set the parameters on ground before it takes off?
2017-5-10
DroneFlying
Mojito Posted at 2017-5-10 06:50
Yes, Litchi's Mission Hub allows you to create the waypoints, points of interest, and parameters of a "mission" entirely through their web browser interface and / or through their mobile app before the flight. Then when you want your aircraft to fly that mission you just start up the Litchi mobile app, tell it which mission you want to fly, and it takes care of the rest.
2017-5-10
Mojito
DroneFlying Posted at 2017-5-10 07:00
Thank you  I will have too try it .
2017-5-10
SHamers
Flight distance : 1001020 ft
I use FPV Camera for waypoint missions. No issues with .500 / .600 / .700 - and I think all 3th party app's are using the same SDK interface?
(O yes , one small isuue - when RC is out of reach I get once the message "mission completed". No worries because the plane is still flying finishing the mission)
2017-5-10
DroneFlying
SHamers Posted at 2017-5-10 08:45
That's always been my understanding, yes. The one exception might be Autopilot, which I understand dynamically controls the aircraft during the mission instead of uploading instructions to the aircraft at the beginning.
2017-5-10
SHamers
DroneFlying Posted at 2017-5-10 09:02
Correct - but I like the indepandacy of the Aircraft, even when the RC is out of reach.
(Of course I keep trying to keep RC connection ;-)
2017-5-10
simsurf
Flight distance : 327497 ft
If dji made an app that didn't crash constantly on my supposedly supported nexus 6p then litchi wouldn't exist...
2017-5-25
Dronoob
Flight distance : 126079 ft
simsurf Posted at 2017-5-25 23:17
Not true. I am using Litchi to capture 360° panoramas and to get the "course lock" flight mode. Both features are not available in DJI Go 4.
2017-5-25
IVAN01
Flight distance : 559938 ft
Russia
Actually there IS course lock in the DJI Go
2017-5-26
No1much
Flight distance : 143878 ft
Some of us just find Litchi to be more stable on our particular devices, and/or prefer their user interface over DJI GO. Your mileage may vary, of course. (In my case, Litchi uses about 30% less phone battery per flight on my Note 4, and I find the Litchi UI more comfortable to use.)
2017-5-26
