fansa84fe8a4
They do look soft. Seems like trees and greenery are usually the first to get smoothed out too if the post-processing is weak.
I don't know your post-processing with your P4, but I'd suggest you trying out the trial version of DxO OpticsPro 11 as it has a DJI P4 in it as a module. Just click on the Apply Preset once you have your DNG file in it and see how it looks. With it you should use their PRIME engine and the tree detail should become evident. That program will correct a lot of the wide angle distortion too. If it can't make something better out of your DNG file, then time to suspect your camera.
