SOLAMAN63
Flight distance : 255331 ft
feorr1 Posted at 2017-4-9 09:47
its a process but can be done you have to delete flight logs from app first connect to network then pull flight logs then select flight logs you want to delete swipe the to left and trash can image should appear tap on that once all your old flight logs are gone it should change .
Thank you, it worked |
