Second controller standard case insert
689 2 2017-4-10
Deanopeps
Flight distance : 233474 ft
Hi all,
Just in case (pardon the pun!) you did not know...
If you buy a second controller for the Inspire 2, the box comes with two foam mouldings around it. You can take one of these and fit it into the standard Inspire 2 case so the second controller fits in the same way as the first. The moulding is the exact same material.
Hopefully you have not thrown your boxes away!
All the best
2017-4-10
I 2 Fly
Flight distance : 8176 ft
South Africa
Thanks! If you have done this, will you please post a photo or two??
2017-4-11
Cobra44Magnum
Flight distance : 935135 ft
Thanks for this info. I have seen videos and photos online that show the 2nd controller in the case but never knew where they got the mount. I haven't thrown away my original box so, when I get home, I'll give this a shot.
2017-4-11
