NFZ limit message with Firmware 600
10757 25 2017-4-12
jerome42
Flight distance : 10617 ft
Hello !
I have the message NFZ limit with firmware 600 but I am not in a NFZ zone.
I had a message to download NFZ but it fails.
How to download NFZ to solve this problem ?
2017-4-12
Dronoob
Flight distance : 126079 ft
I had the same. The controller said "NFZ limit" and the app prompted me to update/download NFZ data. The download progress remained at 0% for about 10 minutes. I have no idea how to start an NFZ update.
After a restart of RC and drone, everything seems to work normally again but the whole story left a bad taste. Could anyone please explain what happened? All similar postings in this forum seem to end with questions but no answers.
2017-4-12
Juаrez
Flight distance : 207513 ft
Belarus
A similar problem, indoors and outdoors on the screen of the RC message NFZ LIMIT .  I here in free fly zone
2017-4-12
alirz5
Flight distance : 609833 ft
So whats the word on the from DJI. Are we not able to fly indoors anymore also?
2017-4-12
Bintryin
Flight distance : 164406 ft
Same problem here but went away out side
2017-4-12
Dronoob
Dronoob Posted at 2017-4-12 12:49
A short explanation about my concerns:
1-2 weeks ago someone wrote here about a crash. He was taking off and flying not knowing that he was in an NFZ. After 25 seconds of flying (and 25 seconds of GPS availability) the Mavic noticed that it was in an NFZ and forced an immediate auto-landing. Unfortunately, the Mavic was over a lake at that time. Luckily the pilot could mitigate the crash by flying the landing Mavic into a nearby tree.
I really, really, really would like to avoid that something like this happens to me because the NFZ-database is confused or updated during the flight. The fact that the RC said "NFZ limit" after the firmware update although nowhere near my position was an NFZ is quite concerning.
I do not want to fly the Mavic with those concerns. A short DJI statement that it is save to fly after the NFZ update failed, would be really appreciated.
2017-4-13
DroneFlying
Flight distance : 10774613 ft
I believe I've seen someone from DJI (Ken?) suggest turning GEO off when you run into a problem, so you might give it a try.
2017-4-13
DroneFlying
Dronoob Posted at 2017-4-13 00:36
I know the post you're talking about, and part of the problem was that the OP powered on his Mavic and immediately flew off before it could even acquire GPS. Give your aircraft enough time to acquire GPS -- and maybe a little longer -- and you aren't likely to have a problem. I don't live in or near an NFZ, but if I did the extra 30 seconds or so that it would take would certainly seem like a worthwhile sacrifice to make to have more confidence I wouldn't crash.
2017-4-13
Dronoob
DroneFlying Posted at 2017-4-13 02:48
Sorry, but your analysis is not correct. The aircraft got GPS during the flight and continued its flight for about 25 seconds. Then it suddenly noticed that it was in an NFZ and immediately started the landing procedure. If it had started the landing procedure the moment it acquired GPS signal, the drone would have been 5m from its starting point and landed safely. Unfortunately, 25 seconds later it was over the lake.
Nonetheless, this is not the issue in this thread. It was just an example that NFZ issues can become expensive and should be avoided. So, back to the original topic:
The RC gave me an "NFZ limit" warning after the update and the NFZ database updated failed. Is that a serious issue? What is recommended by DJI now? Can we restart the NFZ update? Is it safe to ignore the NFZ update? DJI, please advice!
2017-4-13
Griffith
Flight distance : 98537 ft
Same here. The new NFZ file did not load.  After rebooting,  I tried to get back to the point I could upload the new file but couldn't find any indication of needed updates.  I suppose it was just a glitch in the firmware update and the new files will be available later.
BTW, as a routine pre-flight check, I always use B4UFLY to check for airspace boundaries in my area to avoid the kind of forced NFZ landing mentioned above.
2017-4-13
trica de
Flight distance : 1062090 ft
I was the guy with the problem yes, I did not tested the new Firmware and I dont think they added something in the new release because just ONE guys did complaint
2017-4-13
Dronoob
trica de Posted at 2017-4-13 05:20
Yes, that was you. I am not concerned that the same happens to me that happened to you (although I have still the opinion that the 25 seconds delay caused your troubles and that should be fixed by DJI). I am concerned, that my controller gave me an "NFZ limit" message after the update and the app tried to update its NFZ database and failed.
Let me assume the worst case: The NFZ database is broken and during flight the Mavic thinks I am in an NFZ and initiates auto-landing in a very bad place (over water or a road).
I just want to hear from DJI that it is safe to fly (or how to fix it).
2017-4-13
DroneFlying
Dronoob Posted at 2017-4-13 04:53
Specifically which part of my "analysis" was incorrect? What I stated is correct: that part of the problem in the thread you referred to was that the OP took off before the Mavic could acquire GPS. And yes, there appeared to be a gap between when the Mavic acquired GPS and when it figured out it was in an NFZ, but my point was accurate and stands: a little patience would almost certainly have prevented the crash described there. Had he waited a little longer to take off, the Mavic would have recognized it was in an NFZ and refused to take off.
What you wrote in the post I replied to was that you "really, really, really would like to avoid that something like this happens to me because the NFZ-database is confused or updated during the flight."
There's no evidence in that thread that the NFZ database was "confused" or that it was updated during the flight. There is, however, evidence that it's not a good idea to take off immediately after powering on the Mavic, which is what I recommended against.
2017-4-13
trica de
I will go out later and give it a try...
2017-4-13
Danny-B-
Flight distance : 306640 ft
The issue seems to be when you have a weak GPS signal, like indoors etc this NFZ message appears. if you have no GPS its ok and above 12 or so it will be fine. Turning off Geo is a good shout
2017-4-13
Dronoob
Morepeople seem to have this issue. See thread: NFZ limit
2017-4-14
trica de
trica de Posted at 2017-4-13 05:33
so far no problems but I have to say I had 12 satellites
2017-4-14
SkunkWerxs
Flight distance : 231217 ft
Dronoob,
               I'm in agreement with DroneFlying --- it is INPERATIVE to wait for the Mavic's control system to acquire GPS signal.
                I have been numerlessly upgrading and downgrading my FW -- trying to isolate an issue that has nothing to do with this thread and I've noticed every time I upgraded back to 600 FW my controller gave me the NFZ LIMIT popup and I'm nowhere , anyhow, anyplace near a no fly zone --- I wouldn't worry too much about it --- Just keep it in the back of your Mind when you fly and make sure your nowhere near a NFZ ---- Some food for thought --- some people think that fly near or in-between very close NFZ's is OK and wind up flying into the NFZ and regret it --- I even heard of people flying in an area for small plane little traffic airfield zone's that were not classed as a NFZ and they still ran into trouble --- My whole point of this post is wait for GPS lock and don't fly anywhere near (within 5 miles ) of any airport Big or Small -- I understand your concern , no one wants to suffer a loss or crash of there Mavic Craft do to a glitch but keep in mind that all is being recorded --- flight area , control input etc... if you are not near a NFZ and something happened and a NFZ Limit cause you to crash and you did nothing wrong your problem will be rectified --- Remember wait for GPS lock !!!
FlySafe--FlyFree
2017-4-14
boostedford
Flight distance : 144478 ft
i had this issue too
2017-4-14
DroneFlying
Have you tried turning GEO off? I first saw that suggested by DJI but so far I don't remember anyone having tried it and then coming back to let us know whether or not it really helped. I'd be curious to know if disabling GEO really has worked for anyone.
2017-4-14
Jenee 2
Flight distance : 7852129 ft
For those people having NFZ problems on the new firmware, have you recalibrated your compass. I have had no issues on the latest firmware with NFZ but I am not near one either, However, as soon as the firmware was updated, I did calibrate the compass. It is the only thing I calibrate after an update.
2017-4-14
Salegy
Any news about this issue? After downgrade back to 400 all is ok but ...
2017-4-16
jpno1
Flight distance : 152057 ft
New Zealand
All these issues are because the stupid Chinese government force DJI to add NFZ limit functions and personal monitor functions to their products.
2017-4-17
towheaded-pilot
Flight distance : 35125 ft
I was about to update my mavic to .600 but now, I'm staying at current .400. I agree with some saying you should wait until full GPS lock but if you are flying indoors then this is bad. For those having the issue, are you on IOS or Android and what app version are you running? Over at another forum, a pilot experienced this NFZ limit while flying and the mavic did a forced landing.
2017-4-20
jerome42
If I downgrade to firmware 400. Should I connect every battery to the drone ?
2017-5-8
trica de
give x700 a try its just released ... may this fix it
2017-5-8
