Ex Machina
Flight distance : 1806362 ft
fans3852f831 Posted at 2017-4-12 11:48
Tanks for the reply! i'm using an iPhone 7 plus. I tried to switch from Normal to HD mode. It actually worked, and I got a clear image. Unfortunately it only worked for 2 min. Everytime a switch between the modes I get a clear image for approx. 2 min. and then the stripes returns.
I have flewn in 4 different locations up until now, and I get downlink stream, like in the video i posted, everytime. And it's constant.
Weird. I fly with Normal downlink video on my iPhone 7. Assume you are using the latest Go 4 app and iOS?
I'd reboot the iPhone, force close all open apps after restarting and and see if that helps at all. If not, I'd next replace the lightning cable by completely unplugging the one that came with the Mavic and use the bottom-mounted USB port in the RC with the cable that came with your phone.
If still no love, I'd borrow someone else's iPhone and see it the problem persists. If it does, then it's likely to be a hardware problem somewhere upstream.
Good luck! |
