Shou Screen Recorder for IOS
123
17664 101 2015-3-2
timmer1
Flight distance : 30502 ft
RichJ53 Posted at 2016-5-29 01:08
You need to trust the App in general settings. Watch this video
https://vimeo.com/161860125
That was an awesome video, thanks!
2016-5-28
Cougar1
Flight distance : 924393 ft
RichJ53 Posted at 2016-5-28 13:55
Again cougar you are a life saver   I tried your link and Airshou installed with my ShouTV also  ...
Hi Rich, you got it, exactly correct. If you like to save some files/videos (just in case) export them to camera roll and you be fine.
If you have an issue just use the same link and reinstall.
2016-5-28
Romi
Can you have this app record the audio from the tablet or smart device simultaneously to the screen recording?
2016-5-29
RichJ53
Flight distance : 1837356 ft
Romi Posted at 2016-5-29 21:06
Can you have this app record the audio from the tablet or smart device simultaneously to the screen  ...
Yes, the mic can be active while using the App
Rich
2016-5-29
Romi
RichJ53 Posted at 2016-5-29 21:07
Rich
Great, thanks! I want to use this app as a "Blackbox" of sorts.
2016-5-29
Romi
Where is the option to record screen? When I installed the application and logged in with an email it brought me to a page full of other people's videogame streamings.
2016-5-29
Romi
Disregard the above post ^^^
I figured it out by using iosem.us
Do you guys prefer 1080p recording or is there even a significant difference in quality between that and 720p when using the DJI app?
2016-5-29
RichJ53
Romi Posted at 2016-5-29 21:32
That sounds like the Shou TV App... anyway use this video to help you get it going
Rich
2016-5-29
Romi
RichJ53 Posted at 2016-5-29 21:35
https://vimeo. ...
I used this video:
When I tried to do it through the link provided in other videos it would still install the version of Shou that was solely gaming streams. After following the instructions in this video it looked like the normal recording app that everyone is using.
2016-5-30
RichJ53
Romi Posted at 2016-5-30 15:56
I used this video:
When I tried to do it through the  ...
romi
I followed the link that cougar1 gave me to install the Airshou App... not the one for iTunes store
"Hi Rich,
Try:
cherryroad.xyz/airshou
Works fine for me on latest IOS firmware.
I don't have the Shou from iTunes installed on my iPad, only the recorder that is in this link. When logging in I use the same log in as with the App store Shou."
I also deleted the Shou TV App that I used to have because I do not need the gaming stuff.
sounds like you have figured it out and you are all set...
Rich
2016-5-30
Romi
RichJ53 Posted at 2016-5-30 18:40
romi
I followed the link that cougar1 gave me to install the Airshou App... not the one for iTune ...
Yup! It's working just fine on my iPad and iPhone, even recording audio from the smart devicehttps://forum33.djicdn.com/data/attachment/forum/file:///Users/romialmeda/Desktop/INSPIRE_PICS/SCREEN%20CAPTURE/Screen%20Shot%202016-05-30%20at%2011.30.17%20PM.png
2016-5-30
Ricky Wu
Flight distance : 1360719 ft
this is awesome
2016-6-16
Thomas.
Flight distance : 81132 ft
SkySight Posted at 2015-3-10 02:42
Apple took almost a month just to approve the DJI Pilot App and that's  from a huge multi-million  ...
Can you tell us about your experience with the iPad?
2016-6-18
RichJ53
Cougar1 Posted at 2016-5-28 11:12
Hi Rich, you got it, exactly correct. If you like to save some files/videos (just in case) export  ...
Hi again. Shou has stopped working and will not install fresh from the last link cherryroad.xyz/airshou.
Do you have a new link that works with the las test IOS.
Rich
2016-7-19
Cougar1
RichJ53 Posted at 2016-7-20 02:24
Hi again. Shou has stopped working and will not install fresh from the last link cherryroad.xyz/ai ...
Hi Rich, same link still works. Just replaced on one of my devises
2016-7-20
RichJ53
Cougar1 Posted at 2016-7-20 06:13
I have a new iPad mini 4 and the App was put on last month. it would not verify anymore under general settings... so I uninstalled it and cant get this to load all the way (times out).
I will try it again today.
Edit:   okay after rebooting and letting this iPad sit for awhile... I tried it again and this time it installed and verified the App in general settings. logged in and it is working. What a pain in the butt... Seems like this App just has a mind of it's own
Rich
2016-7-20
tedven24
Flight distance : 203133 ft
As long as you start the recording in the Go App, can you switch to another SDK app like Autoflight Logic's Autopilot and still record?
Thanks
2016-7-20
Cougar1
tedven24 Posted at 2016-7-20 15:32
As long as you start the recording in the Go App, can you switch to another SDK app like Autoflight  ...
If you are referring to Shou recorder, you can record anything on the iPad. No need to be in any specific app, just start recorder and then do as you want.
2016-7-20
jeffcard
Apple is quite strict with screen capture tools. One alternative solution I just found is to use Acethinker iPhone Screen Recorder to mirror iphone to computer and then make the recording. It's not that direct, but it works.
2016-11-15
ChristopherLi
China
In fact, there is not just one IOS recorder. And this app takes up too much RAM. There is a recoder called ScreenMo which can finish the ios recording all on PC. That makes you ios device not choppy and your recording more fluent.
As for Android screen recorder,you can try the built-in recorder in Google game plays.
2018-7-29
ChristopherLi
China
ChristopherLi Posted at 2018-7-29 19:18
I add a link for your quick reference: FonePaw
2018-7-29
CharlieZ
Flight distance : 623432 ft
Cool, thanks for sharing!
2019-1-11
123
