3.58 miles One Way - Do you think the mavic will make it?
1449 25 2017-4-14
RedTailHawk36
Flight distance : 978553 ft
I've been flying both of these places but at seperate times. I have straight line of sight. Starting Elevation is roughly 1,400 ft higher than end elevation.I have to coordinate where I have a spotter on top of the hill and also at the LZ to send live video feed of the landing. What do you guys think? Will I loose the mavic over the water?
Google maps route
2017-4-14
4wd
Flight distance : 545817 ft
It's going to lose signal when near the groud, you'll need to get in roughly the right spot and autoland.
I'd check what happens during Autoland if control is turned off.
2017-4-14
MacIak
Flight distance : 3419 ft
Belgium
The route is SW-NE? The clear LoS and water will help the signal I would not worry about that. Also battery should be no issue. The only thing is make sure to have enough altitude so you keep LoS during descent and set RTH to hover. Testing on a " safe " location would be good to see how autoland behaves when the mavic is not in front of you (or how you deal with that). Just keep a good eye on the signal so it won't "RTH" when over water off course when signal seems stable you can change from " homepoint" to " hover" after PNR.
2017-4-14
The Rev
Flight distance : 1256837 ft
I would use Litchi to do this and set land for end of mission
2017-4-14
4wesomeAdam
.....No.....
2017-4-15
MaKelly
Flight distance : 359869 ft
MacIak Posted at 2017-4-14 22:51
.... " hover" after PNR.
PNR... Point of No Return?
2017-4-15
MacIak
Belgium
MaKelly Posted at 2017-4-15 00:50
Affirmative
2017-4-15
hallmark007
Flight distance : 9827923 ft
Flying over water is usually best place for signal , very little interference, you could use some cheap parabolic signal senders,
Wind may be a factor if your flying high, Mavic can have real trouble when flying into strong winds, so make sure and check the wing and gust speed .
Your question will you loose it over water, well you nearly have as much land to cross as water,
Although you can't really have a plan for it dropping into the lake, try to have some sort of plan if anything goes askew over land.
Just make sure you have record button pressed. Good luck.
2017-4-15
SkunkWerxs
Flight distance : 231217 ft
RedTail, I think you'll make it ---- Go to the area your going to land , make it your RTH --- go to where you want to start off hit the RTH button and just keep checking for loss of signal B4 you pull off a manual flight like that --- doing it this way is a little more safer just incase you loose the signal it will still complete the flight distance to the point you set and land
2017-4-15
DroneFlying
Flight distance : 10774613 ft
It'll come down to the wind (speed and direction) and how fast you fly: the Mavic is definitely capable of making it that far on one battery, at least if it's not flown at maximum speed. In fact, with light enough winds it could even make a round trip. And if you fly it with a tailwind I predict that you'll make it there with at least 50% battery still remaining -- assuming, of course, that it started at 100%.
P.S. I'm also assuming that it's stock with no extra weight (e.g., landing gear extensions) attached.
2017-4-15
RedTailHawk36
Ok, I'm hearing many great suggestions from all you that have more drone experience (thanks guys!).
If I do it I will be hitting the record button for sure.
I was also looking to see if there were any legality issues.
I figured if it was illegal one of you smart guys would have popped my bubble and told me this.
So from the lower point I flow across the lake to the mountains easily and had tons of battery and signal. From the mountains I have been less courageous. I noticed dropping in elevation takes very little battery but climbing in a head wind makes my palms sweat.
It will come down to tailwinds. I'll keep you guys posted...thought it would be a fun mission.
2017-4-15
RedTailHawk36
Pretty much. This is the route. I would have a strong head wind in the afternoon, nothing in the morning.
I like your testing idea. Worth a try before I send my $750 drone out to it's death.
Thanks for the suggestions.
2017-4-15
RedTailHawk36
Ha! A brutally honest answer
2017-4-15
RedTailHawk36
Was wondering too...
2017-4-15
RedTailHawk36
SkunkWerxs Posted at 2017-4-15 03:15
I've seen these things return to home....they move so slow. I could try that but I'd be worried it will take it's sweet time getting there.
2017-4-15
RedTailHawk36
DroneFlying Posted at 2017-4-15 04:35
Totally stock. Just found this cool new app that lets you record the screen so I'm anxious to try it.
2017-4-15
DroneFlying
RedTailHawk36 Posted at 2017-4-15 05:57
Then you'll be fine as long as you don't have a very strong head wind. Just remember that the wind at altitude can be very different from ground level and again, if it's feasible then wait for a tail wind or at least a cross wind.
2017-4-15
RedTailHawk36
DroneFlying Posted at 2017-4-15 05:56
That's right. I was going to facetime my source at the landing zone and see if he could provide some verbal guidance and maybe video.
2017-4-15
RedTailHawk36
I like the idea of taking it out from the LZ and trying the RTH function over the lake with the LZ as the home point. See how the Mavic behaves on a RTH when out over the lake. Thank you SkunkWerxs, MacIak and everyone for their feedback. If I do it I will document and let you guys know if it worked.
2017-4-15
Gary Mac
Flight distance : 741683 ft
My thoughts:
Home point gets updated when you power on the Mavic, so setting it at the LZ would not be feasible.  However, you can update the home point at anytime, so flying it to the LZ, looking down for your exact landing point while still high enough for signal, and updating the home point would be a good start.  Test and practice before your attempt.
Once your home point is updated, I'd initiate an auto land and watch the video for minor corrections.  Make sure your LZ is large and clear.
This type of thing has been done... watched an interesting video on YT of the guy flying from mountain to his villa and landed on his patio.  Talk about making your palms sweat.
Battery life is not an issue.  I covered nearly 6 miles on a 2.5 mile each way over the water and then some flying when I returned with battery to spare.
Don't forget to drop your altitude as you go so that you stay at or under 400 feet AGL.  I know, you'll have to estimate and it is nit-picky, but it is the law and best to try to follow it.  Besides, you don't want to reach your destination at 1400 feet... just in case there is an aircraft in the area.
Sounds like fun... post up the results!
2017-4-15
RedTailHawk36
Gary Mac Posted at 2017-4-15 07:02
My thoughts:
Starting to realize I need better planning for this. I don't want to lose my Mavic. Too much fun in such a small package. Well you know...
2017-4-15
AG0N-Gary
Flight distance : 700846 ft
Your map shows a considerable drop to the landing zone. You'll lose control as you drop over the hills to go down to landing.  What are you going to do about that?
2017-4-15
High FlyerCokie
Flight distance : 701109 ft
New Zealand
Only one way to find out.......................keep us posted
2017-4-15
RedTailHawk36
AG0N-Gary Posted at 2017-4-15 18:10
Landing on top of the hill on the other side. Never lose line of sight with the drone.
2017-4-16
RedTailHawk36
Well I was experimenting on the other side of the lake and this is what I did. It was a good run.
Small Scale Test
2017-4-18
Vasco
Flight distance : 5427717 ft
Greece
i think that in order to land your plane safe , and due to the fact that you will loose signal during descending you have to use auto land during Mavic  is above landing position (and after off course you have double check that surface is ok for landing ) and before loose signal but also you have to switch off land protection , because if for a reason plane decides that surface is not suitable for landing it will stop the procedure and when loose signal it will start coming back to take off position .
2017-4-18
