Elevation change behavior questions
453 2 2017-4-18
gabriel.magana
Flight distance : 177254 ft
Hi everyone, relative n00b here.
What is the behavior of the P4P when it comes to taking off from one elevation, and then flying off cliffs or sudden big elevation changes?  I remember an early problem with the mavic was when a guy flew his off a balcony and the drone plummeted downwards, and I've been afraid of doing so ever since :-)
For example, when I take off on top of a cliff, say at 400 ft above ground, then go up 200 more feet, which is the elevation ceiling that applies when I fly beyond the cliff, 600 feet above ground?  Is it based off the home point? If I return to home while beyond the cliff, will the drone actually descend because of the 400 ft height of the cliff?
2017-4-18
DJI-Jamie
Flight distance : 112405 ft
If you're at the top of a hill, for instance, that take off point will read as 0 ft. and record the altitude from that point. If you rise 20 ft. and go straight off the cliff, it will still read as 20 ft.
2017-4-18
gabriel.magana
Thank you!
2017-4-19
