Precise heading for POI in Litchi
2224 11 2017-4-21
piowoc73
Hi,
I was wondering if somebody can help me with the following issue:
When flying pre-planned waypoint missions in Litchi I realized that the gimbal heading is not always accurate for some reason. I am not sure if I am doing something wrong, or if this is some compass inaccuracy. I always use the road map and not the aerial map when setting up the points of interest, but still, the gimbal heading isn't perfectly on the spot. Any ideas how to resolve this issue?
Thanks!
2017-4-21
RicardoGray
Flight distance : 4356421 ft
Go to flyLitchi.com and watch the videos. They explain in detain how to program for specific POI, gimbal degrees, etc.
2017-4-21
PhanFran
Flight distance : 4804163 ft
Belgium
And don't forget that you can not control gimbal pitch with Litchi when there is no connection with the RC. You can have exact gimbal pitch even without RC-connection with GS Pro from DJI but that app has no POI-features...
2017-4-23
piowoc73
PhanFran Posted at 2017-4-23 07:54
Yeah, in my opinion, GS Pro is far behind Litchi.
2017-4-23
PhanFran
Belgium
piowoc73 Posted at 2017-4-23 08:16
Well, I don't agree. Since GS Pro is available I never use Litchi anymore; just because, at least with GS Pro, you can direct your camera in the right direction even when the RC-connection is lost.
2017-4-24
piowoc73
PhanFran Posted at 2017-4-24 10:57
Does GS Pro still offer only straight line routes between waypoints? If so, then it's definitely inferior to Litchi in terms of video production.
I am not sure how you can control anything if you don't have the link between the RC and the aircraft. Are you talking about the loss of just video link or the control link?
It's still not available for Android, which is a real shame for DJI, so I am unable to use it anyway.
2017-4-29
PhanFran
Belgium
piowoc73 Posted at 2017-4-29 09:42
1) Yes, GS Pro can be set to make curved turns and you can set the radius of each curve separately.
2) Yes, with Litchi and  GS PRO you can very well  make the phantom fly wherever you want without connection with the RC. The whole flight with all the waypoints is uploaded to the Phantom and the AC will execute the route completely autonomously. You can even switch your RC off if you want. So it is indeed NO connection at all, no Download and NO UPloadlink.
Just an hour or so ago my P4P made a 22 minute flight. After a few minutes connection was lost and I just switched the RC off and went for a cup of coffee. After some 16 minutes I switched the RC back on again and after a minute or so the connection was re-established with the AC and it landed nicely on the spot where it took off, after a total distance of 8,5 km, some 4 kms forth and back.
So you do NOT need connection with the RC , not with Litchi and not with GS PRO: all the data are already onboard the AC before it leaves the ground.
Just make sure that your last waypoint is close enough to your point of take-off and don't make waypointflights that will take longer than 22 minutes or so to make sure the AC reaches it's departure point safely.
3) GS PRO is FREE and has one big advantage: the pitch of the gimbal at each waypoint is correctly set at the right moment, just as you programmed it preflight even WITHOUT connection to the RC.
Litchi is NOT FREE and the pitch of the gimbal is not set anymore after the connection with the RC is lost.  It stays then at the angle it was on at the moment the connection was lost (but the AC , of course, continues it's preprogrammed route without problems).
2017-4-29
piowoc73
PhanFran Posted at 2017-4-29 11:37
Yeah, the only problem is that GS is not available for Android, which is a bummer for me.
Also, as far as I know there is no way to pre-plan the missions online like in Litchi Hub.
2017-5-3
PhanFran
Belgium
piowoc73 Posted at 2017-5-3 06:41
True, there is no 'Mission Hub' online for GS Pro but the setting of the waypoints on an iPad Air 2 for example is going smoothly.
2017-5-4
fans63bbc718
Flight distance : 163855 ft
Have been playing Litchi almost 4 months now trying everything with waypoint mission.
Just today I found out that the gimbal pitch tilt up/down won't work if AC lost connection with RC. Is this a glitch?
2017-6-10
PhanFran
Belgium
fans63bbc718 Posted at 2017-6-10 04:34
Please read post #7 above...
2017-6-10
fans63bbc718
PhanFran Posted at 2017-6-10 05:48
I see, but mine instead of staying in position its bounce up and down (out of range). Seems that Gimbal pitch in waypoint must have RC stay in range. Too bad GS Pro is not available in IPhone. Thanks
2017-6-10
