P4 firmware update file requested
838 5 2017-4-22
fans7f04b591
Flight distance : 1238980 ft
Iran
Hey there and thanks for reading this.
I accidentally attached an SD card including P3P files into my P4 aircraft. It updated the aircraft and now it's recognised as P3P.
Can anyone please share the P4 aircraft firmware update file so That I could copy it on my sd card and attach it into my P4 for getting it to work again?
Thanks
2017-4-22
fans7f04b591
Iran
No answer?!
2017-4-22
Aardvark
Flight distance : 384432 ft
The file is not directly available, the P4 is updated via DJI Assistant 2, or via the DJI Go4 App'. Unlike the P3 series the file is not available for direct download (or at least not as far as I know).
2017-4-22
fans7f04b591
Iran
Aardvark Posted at 2017-4-22 12:13
Thanks but unfortunately My Bird doesn't update with the provided ways (either dji assistant or dji GO app). Both fail at 5% of progress
2017-4-22
fansa84fe8a4
Flight distance : 3 ft
fans7f04b591 Posted at 2017-4-22 13:06
Sounds like it must go in as the firmware will not load, probably a glitch in the microprocessor's E/PROM.
I've programmed enough micros to know they do not always take a subsequent flash burn (i.e. another firmware update.).  Things get stuck memory addresses and are sometimes defective on subsequent burns.  One of my camera's had a bad firmware update off a BIN file and had to go in for a new processor.  It had been through a couple of flash burns prior, but the third was the charm (Not!).  Stuff happens.
2017-4-23
Visual Air
Flight distance : 2710115 ft
That sucks. I have not seen any upgraded software in a while for the P4, Will DJI release new updated software or is that it?
2017-4-23
