DroneFlying
Flight distance : 10774613 ft
In airspace class D, do you need an authorization to fly regardless of the altitude?
The FAA requires recreational fliers to notify any airport within five miles of where you're flying regardless of the airspace / airport size.
For instance, do you really need an approval even when you are flying around 20ft AGL?
Yes, the altitude doesn't matter.
Speaking of airspace authorization, is it possible to obtain long-term authorization?
The FAA's verbiage is a little vague on this point. It says that you have to notify them of your flight plans but doesn't explicitly say you have to call daily, for example, if you plan to fly on successive days.
I know by the rule that I am required to notify these nearby heliports, but sometimes it seems utterly unrealistic, espeically when dozones of airports pop up in the screen?
Yes, as you mentioned, many of the B4UFLY areas are heliports and even with some of the smaller airports it's difficult and sometimes even impossible to find out how to contact.
What are you guys' take on this?
I think if you can make a convincing case that you made a good faith effort to follow the rules that you're very unlikely to get in any trouble even if you don't, for example, successfully contact every single airport and heliport with five miles.
P.S. One last very important point: you don't need "authorization" from those airports and heliports but are simply required to notify them.
Can an airport operator object to model aircraft flights near an airport?
Yes, an airport operator can object to the proposed use of a model aircraft within five miles of an airport if the proposed activity would endanger the safety of the airspace. However, the airport operator cannot prohibit or prevent the model aircraft operator from operating within five miles of the airport. Unsafe flying in spite of the objection of an airport operator may be evidence that the operator was endangering the safety of the National Airspace System. Additionally, the UAS operator must comply with any applicable airspace requirements.
Unmanned Aircraft Systems (UAS) Frequently Asked Questions
