Loadnabox
With the drone on, and controller connected to mobile device, go to "general settings" Firmware should be at the top
If you're experiencing problems with video downlink you only need to downgrade the controller firmware. Leave drone off, connect controller and device. Tap and hold the menu button at the top right (need to hold several seconds). A different menu will pop up asking which version you want to install. 1.6.0 works best apparently |
