fansa84fe8a4
As mentioned, try flying a waypoint box pattern over that field with the waypoints all at the same height. I've done it with Autopilot and a P4 and the mystery to me is that the P4 will fly the correct height outbound, but on a return leg it will be higher, maybe 15 feet. If I allow it to continue, the outbound drops down to the correct height again, and the inbound climbs up again. Very odd, but seems direction oriented too. The GO screen number are all over the place so I cannot rely on them compared to what the video shows with the climbing height. It often lands -40 feet showing in GO while takeoff was at zero.
Autopilot has a setting where you can control the flight altitude tolerance. I think default was 45 feet and the tightest was 15 feet. I set it to tightest and it still shows return leg higher than outgoing. Dunno. |
