What is "Peak Focus Threshold"?
13784 11 2017-4-25
Trent Mavic
Flight distance : 1098924 ft
Hi, just going through the settings and I see " Peak Focus Threshold".
I know I could look through the manual but I'm sure the community could explain it better for an ametur.
So, yes, as the title says??
Thank you
2017-4-25
Trent Mavic
For some reason it puts a smiley...
2017-4-25
Trent Mavic
For some reason it puts a smiley... It is Peak Focus Threshold
2017-4-25
Ex Machina
Flight distance : 1806362 ft
The Peak Focus feature adds a kind of red static-looking effect around edges to indicate focus, the Threshold setting adjusts the point at which the effect activates. Some find the feature annoying, I find it useful as a focus reality check.
2017-4-25
Mcflying
Flight distance : 243753 ft
Small word of caution.
When you use this feature on an Android device which is not recommended/approved by DJI be prepared that this will cause the DJI GO4 app to crash.
2017-4-25
Xman1
Mcflying Posted at 2017-4-25 12:11
I just took one hour of video with Standard enabled and it didn't crash.
2017-4-25
Mcflying
Xman1 Posted at 2017-4-25 12:12
Then you are lucky.
My Rokitokki low budget android device crashed every single time i have used the threshold function.
2017-4-25
Xman1
Mcflying Posted at 2017-4-25 12:23
Then you are lucky.
Check your phone for rogue apps.  Go into settings -> Apps and force close anything that you don't need.  Also I suggest you turn on airplane mode when flying.  Also make sure the DJI app has permission to access your phone as it seems to be more unstable for me if I don't, but maybe that is just my phone.
As for memory, a 2GB device should work fine as I see the app only using about 235MB of memory when in operation.
I am still testing to find what causes the app to fail, but it seems to want to play nice when I am testing lately and not crashing.  This is why I have 1 hour of worthless video with Peak Focus on....  I was testing to figure out what makes the app crash, and I can't get it to crash lately.
2017-4-25
Mcflying
Xman1 Posted at 2017-4-25 12:41
Thanks sharing.
Will give it another try later this week wih these tips.
2017-4-25
Trent Mavic
Thanks for the replies
2017-4-26
mschwa01
Flight distance : 218783 ft
Ex Machina Posted at 2017-4-25 11:09
Standard is not an option on IOS. Is it Normal now?
2017-8-30
Ex Machina
mschwa01 Posted at 2017-8-30 15:27
On iOS the Focus Peaking settings are High/Normal/Low/Off.
2017-8-30
