Jason Lane
Flight distance : 260144 ft
Philippines
CelticWarrior Posted at 2017-4-27 06:43
Looking at those logs although you must take them with a pinch of salt, and information is not always correct.
But this is all we have to go on, first your environment it was very built up area, at 2500 ft you were already getting signal warnings and you continued to carry on before you lost signal, the log shows that the signal to remote and aircraft were interrupted several times, this could be caused by lack of signal or too much interference, eventually you ran out of luck, but s**t happens and it obviously did here.
Going by what you have said , I would surmise that when you finally lost signal your AC tried to return home and OA did in fact work, as you say it stopped in front of the building then climbed which is correct procedure, but if there was over hanging balcony then Mavic can't see this and behaved properly by crashing into it. That's all I can see from your log.
"Going by what you have said , I would surmise that when you finally lost signal your AC tried to return home and OA did in fact work, as you say it stopped in front of the building then climbed which is correct procedure, but if there was over hanging balcony then Mavic can't see this and behaved properly by crashing into it. That's all I can see from your log."
I was thinking that, too, but the way the Mavic seemed to immediately change from forward flight to vertical flight doesn't seem normal for OA during RTH. I think it usually stops abruptly first, and then after a pause it starts to ascend. It all seemed to happen too suddenly in this case. Although I admit I've never witnessed my Mavic doing OA during RTH. |
