Adding Filter to X5S 15mm Stock Lens
1044 2 2017-4-28
RichfromHowellN
Flight distance : 508255 ft
On the stock 15mm Lens that ships with the X5S has a blank ring behind the lens hood.  I assume this is a balancing ring.  If I want to add a filter to my lens, should I screw the filter directly into this blank ring behind the lens hood or should I replace the blank ring with my filter and then put the lens hood back on?
2017-4-28
Aeromirage
Flight distance : 1778045 ft
I don't have the X5S but it uses the same lens as the X5. That is a rebranded Lumix 15mm. Use filter in place of the balance ring and still use the plastic hood. That's what worked on the X5, should be the same on the X5S.
2017-4-28
RichfromHowellN
Aeromirage Posted at 2017-4-28 14:51
Awesome ... thank you!
2017-4-28
