endotherm
Flight distance : 503241 ft
I have checked your flight log for you. It accurately records your flight and it shows the flight exactly as you described. Thanks for a very detailed description of your observations for a change!
Everything ran perfectly up until you changed the altitude setting. During this time your speed slowed to 0 mph while holding an altitude of 390ft. It continued correctly for another 37 seconds at which point you applied a little left stick up for a short period. There were no further stick inputs recorded for the remainder of the flight. At this point we see the aircraft rotating rapidly and the camera gimbal go out of the normal operating range of -30° to 90°. This is a typical death-spiral as the aircraft goes out of control prior to a crash, and the aircraft tumbles and inverts. However, incredibly, your aircraft quickly recovered from this and actually gained 15ft altitude! At this point, I thought you may have had a small birdstrike, sufficient to upset the flight, but minor enough to be able to quickly recover. Your speed varied betweed 0-20mph as it retained an altitude of 400ft.
At 306 seconds into the flight, it records your RTH "go_home" command. It turns to point approximately towards home, facing around 110°, while still drifting roughly West. At 316 seconds we see yet another spin and tumble, this time it fell in altitude to 95 feet, impacting with the ground and ascending again to 172.5ft before the record stops suddenly, showing tumbling and rotating the whole time. It may be possible there was a second birdstrike which took the aircraft to the ground, damaging it, and it then tried to take off again to RTH, but the battery eventually fell out. The reasoning is complete speculation by me to try and fit the data. I have no evidence of a birdstrike. At 95ft, the kml data (the flightpath) intersects with the surface of the mountain for a short time, indicating it had hit the ground or foliage on the side of the mountain. Interestingly it was still able to fly and it did ascend, but travelling West, having left RTH mode and entering ATTI.
Another possibility for the loss of control would be severe updrafts in close proximity to the side of the mountain, sufficient to throw the aircraft around and stronger than the 10m/s speed available from the aircraft to attempt to remain stable and come home. The other thought I had was that the mountain may have large iron ore deposits and had a severe magnetic affect on the aircraft compass causing a loss of orientation and crash. However I would expect to see many more error messages in that situation. None of this adequately explains why it had a tendency to drift West, unless there were strong air currents taking it in that direction.
There was a bug in earlier versions of the DJI go software that may fit with some of your circumstances. I am not sure if this was identified properly and published anywhere, although I believe newer software was quietly released which fixed the issue. In order to see if this may be the case, can you reply with what device you are using? Is it Apple iOS or Android? Can you check what version of the DJI go app you have installed? What firmware do you have loaded in the aircraft?
As I remember the bug, there were a set of circumstances under Android with an older Go app, and if the aircraft was flown outside of a limit that was set in the app. The aircraft would create a false home point roughly west 1-2km away. It's possible changing the limit while in flight upset something. There is no evidence of that here, but I'm just being thorough and want to rule the possibility out. Are you certain that you were changing the altitude limit in the app, and not the distance limit, usually associated with limiting the distance flown whilst training?
I'm sorry about your crash, this is indeed a very strange flight and incident overall. The data is very consistent with very few gaps or error messages indicating breaks in the telemetry. The fact that you report seeing it tumble in the video suggests you were well within range and had a strong radio signal. If you can supply the previous information I requested I'll look into this further for you.
In relation to fixing the damage and costs, I'll leave that to others. Perhaps upload a couple of photos of the damage to give us an idea.
