Kokok
Flight distance : 1802159 ft
Philippines
Greetings from the Philippines!
I bought my P4 last Feb 2017 and have been loving every flight with it. All my flights have been incident free since I bought it except earlier today.
After my usual preflight checklist (checked and calibrated everything, all systems normal), spooled it up with 9 gps satellites and as soon as it does, the aircraft nearly tipped over to its back. Shut if off by holding the left stick down. I did not apply throttle after arming the motors with CSC.
I shut down the motors and tried again. This time I had 7 to 8 gps satellites. Armed the motors and applied a bit of throttle to take off. Soon as I applied power, the aircraft tilted backwards and hopped/skimmed on the ground a few feet backwards and grazed the street curb with the rear props. At this time, I was able to compensate with pitch forward control and full throttle down to disarm the motors.
After my failed 2nd attempt to take off, I restarted everything (transmitter, aircraft and mobile device). Everything was incident free after that.
Question is... what could have caused this? could it be that I tried taking off with less than 10 gps satellites?
Any piece of information will be highly appreciated as it will help in preventing a recurrence of this incident.
Thank you!
