Weidyc
Flight distance : 204692 ft
Taiwan
I tried to figure this out but it seems there is a quite a few people out there with the same problem as me.
DJI is really quite on this one.
I along with many users face a connecting problem with certain devices. I'm still not sure where the root of the problem is, as I have both a iPad Pro 12.9 iOS 9.1 jail broken and guess what ?!? It works fine with the latest go 4 app and the RC and AC. But with my iPhone 6S Plus iOS 9.3.1 nothing works. When you power on the controller, then the Mavic pro then open the go 4 app, it doesn't connect. When you plug in the cable you hear the charging confirmation tone and see the charging symbol briefly. When there is no go 4 app, or when it's deleted, the phone ask if you want to download the app or ignore and called the RC device "C2"-. I have tried all that I can short of restoring the device, but I'm pretty sure that is not the problem as I've seen on other forums that tried to do network reset , reset all, and even restore the iOS and still no connection, that guy ended up giving up and used in iPad mini. We need more support from DJI for the iPhone 6/S/Plus/7 users!!
Here are the things I have tried
1. I had go app and go 4 app at the same time becuause go used to support Mavic, but they moved it to go4. I deleted both and reinstalled go 4 latest version, 4.0.8
2. I have downgraded go 4 to 4.0.0
3 I have tried go app 3.0
4. I have tried using original iPhone cable brand new, in the bottom USB port of the controller and I did unplug the original Mavic pro lightning cable that came with the drone, and I tried either plus and unplugged, switch and switch back alternate have both plug in, have one plug in, any combinations you thing of I tried, I tried with 4 different cables thru the bottom, remind you, they all work with the iPad Pro in any combination but with one one cord plug in, it doesn't work with two ports being plugged in.
5. I tried other apps they can connect with the Mavic controller, they all show the same problem, no connection.
6. My Mavic has the latest firmware v01.03.0600, with my iPad
7. This Mavic is new, and I couldn't even activated for hours until I finally gave up and used the iPad Pro instead to do everything
Can anyone with success shine in?
Can DJI please fix this problem with there software? Or is this the controller problem not being able to work with iPhone 6's? |
