The general consensus here is that once a battery takes a swim, you throw it away. There are too many possibilities for it to go wrong and burn up your aircraft. Just not worth the risk.
True fresh water will not harm any battery as it does not conduct. But problem is rivers / lakes etc. have dissolved matter in the water that can create corrosion or deposits when drying out.
The old answer to try rescue items - was to wash with spirit ..... neat alcohol.
All you can do now is leave the battery in warm dry place for a few days to see if it dries out internally. Maybe your switching on while still wet inside has damaged it ... who knows until fully dried out.
I´d use a spry named WD40 here if i had contact problems with water. It´s electrical neutral and pushes the water out of the problem part. A little bit could helps to avoid conducts.
Peterx Posted at 2017-5-1 06:55
WD40 !!
Please put it back on the shelf ... it leaves residues ... once the solvent evaporates.
Number of cars ignitions 'gummed' up by that rubbish being sprayed too liberally is legendary. Should never be let near any electronics.
The best use of WD40 is as a Starter spray instead on Ether based.
But onto the DJI battery ... as its a closed pack - you really have a hard job to dry them out ... and to 'wash with alcohol / spirit' ......
