RedHotPoker
Flight distance : 165105 ft
8Blue Wolf8 Posted at 2017-4-30 21:41
Thanks! I'm just wary as I've read some posts saying swapping batteries resulted in catastrophic failure....I'd hate to have my new bird grounded . It seems it may have been from the very firmware update you mentioned..(ie someone got a P3P battery and stuck it into a P3S...the firmware was updated and then when it was put back into the P3P it wouldn't fly.) Do you reckon I should be good if I do a manual firmware upgrade once it is back in the Pro bird? VERY NERVOUS!
Cheers
Place the battery in the drone, turn on the flight kit as if you were about to fly, and see if an update message pops up on the screen.
The only way you will know, is to check, but they are the very same flight packs. ;-)
RedHotPoker |
