fans2599bb72
Flight distance : 63976 ft
Thanks Natalia,
Will not send, but like I've mentioned there isn't any physical damage to show on the picture.
Here's a quick update on my situation:
I let the drone dry up and fired it up (with a new battery since the old one is not working anymore), to my surprise the drone started up, got all the connections going and I took it out on an easy flight. All works (except the battery that fell in water with the drone)... One thing I did notice: it's not as stable (staying in one spot) as it was when I first started using it, and it varies speed sometimes when I try to smoothly fly it. I noticed that a couple flights before it crashed too, not sure if that's what made me cause to crash in the first place as I was very careful on the control and the drone accelerated itself backwards and kept on going backwards until it hit the wall and fell into a river (without my control input). Now I havn't used the drone very much to know if that is normal behavior or not...
So my question is: should I still send back to drone for repair? or keep and try flying it more to see if it works well...
Thanks for your help,
Ed |
