DJI APP Display size error
6906 14 2017-5-4
AmFam-Lee
Flight distance : 37408 ft
After getting the latest update on my phone for the Samsung Galaxy S8 my DJI GO 4 app will not open. I keep getting this error "DJI GO 4 does not support the current Display size setting and may behave unexpectedly.", I have changed the display size and it still says the same thing. I really hate not being able to Fly!
If you have any suggestions to fix this error please let me know.
2017-5-4
dv8ed
Flight distance : 360322 ft
Change display back to FHD+, delete/re-install app, open app now you should be able to set WQHD & force full screen.
2017-5-4
AmFam-Lee
dv8ed Posted at 2017-5-4 06:57
I uninstalled it a few times but kept it in WQHD. Now its working, thanks for the info!
2017-5-4
Techbrute
Flight distance : 180144 ft
It bears mentioning that the S8 is not currently supported by DJI.  I'm hoping that they are quick to add support for new devices.
2017-5-4
MuttleyoA
Flight distance : 73412 ft
AmFam-Lee Posted at 2017-5-4 07:04
Thank you, thank you
2017-5-5
Hello, please uninstall the DJI GO app first. Then scan the QR code from our DJI website to install the DJI GO 4 app. http://www.dji.com/mavic/info#downloads
2017-5-8
skpManiac
Flight distance : 1092589 ft
DJI Mindy Posted at 2017-5-8 00:24
Why is this not yet fixed, it happens after every update for the past few months and your Devs are well aware of it as its all over this board and Google Play,
2017-5-19
EastyT
Flight distance : 970374 ft
Techbrute Posted at 2017-5-4 07:20
No offense and I'm not trying to be obtuse, but technically DJI GO4 supports any android device 4.1.2 or later.  The published list is "Recommended" devices.  There is nothing that says they support nothing but the recommended list.  And, as a matter of fact, there are many devices on the recommended list that constantly crash, so the list is rather meaningless.
2017-5-19
skpManiac Posted at 2017-5-19 14:49
It's probably you install the tablet version of DJI GO app.
Please try to scan the QR code to install the DJI GO app again.
2017-5-21
skpManiac
DJI Mindy Posted at 2017-5-21 22:01
I did not install the TABLET versions, I have done this many times, it runs perfectly, UNTIL IT UPDATES, then it crashes  - EVERY SINGLE TIME
It's obviously an issue with the update process and one DJI fails to address, like all the other issues on the Osmo Mobile - I am losing patience with DJI recently :/
2017-6-12
skpManiac
It may be something with the Galaxy S7 software,as I am now having to use an old HTC ONE E9+ to fly and that has updated twice with no problems
2017-6-21
b0n3
Flight distance : 21083 ft
Russia
The last update and again this sh.t with the screen resolution on Galaxy S7 Edge....
Dji what's going on?
2017-9-21
Koffieanan
Flight distance : 752749 ft
Also got the same problem with a S7. In the beginning this one is standing on the list with recommended devices. This I checked before I bouoght the DJI Phantom 3A. But after a while they skipped the S7 and since then I got the same problems with the updates.
2017-9-25
Asainz320
Flight distance : 1061594 ft
If you download the apk from the web you will not have this issue. It started happening to me since version 4.1.8 installed from the Play Store. When I downloaded the 4.1.8 version from the web and installed it this issue didn't happen.
2017-9-25
gabriel.magana
Flight distance : 177254 ft
I had the same annoying problems with the GO app (I could not log even a single flight because the app crashed so often. I have a Samsung S7+ dedicated only to flying my Mavic; I have all the latest updates to it, both in apps and OS.
My crashes stopped completely when I lowered the screen resolution to FHD (1920x1080). I've not had a single malfunction since I did that, so needless to say, I'm happy as can be. I do not need the extra resolution for any purpose.  The resolution warnings went away too. I'm on the DJI GO app that comes from the Android App store.
2017-9-25
