Changing Altitude
1392 14 2017-5-5
Doc Larson
Flight distance : 1324987 ft
When I start up an calibrate the drone everything is good to go.  There has been trouble once I fy a short while that significant altitude readings variations without the drone moving.  I've even left the drone idling on the ground and watched the altitude readings climb.  This becomes an issue not only for being lower than reported but when I use some of the autoflight features.  Any help would be greatly appreciated.
2017-5-5
Nigel_
Flight distance : 388642 ft
The altitude comes from a barometer, if the air pressure changes then the indicated altitude will change, there are many reasons that the air pressure may change a little over a few minutes.
How much change are you seeing?
2017-5-5
Doc Larson
Nigel_ Posted at 2017-5-5 12:24
multiple feet....up to 25' sometimes
2017-5-5
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, what kind of areas are you flying in? Did you notice this right out of the box, or after a firmware update or hard landing?
2017-5-5
KM5RG-Robert
Flight distance : 2075213 ft
Try letting it warm up a little more before taking off. Might help.
2017-5-5
Doc Larson
DJI-Jamie Posted at 2017-5-5 14:33
I noticed it starting after using the Autopilot app, it may have been happening before.  I'm in FL, literally 3' above sea level.
2017-5-7
Doc Larson
KM5RG-Robert Posted at 2017-5-5 14:36
I tried that a few times and I could watch the altitude climb increase while the drone is still on the ground.
2017-5-7
Kneepuck
Flight distance : 275105 ft
Be cautious idling on the ground.  I have had mine decide to take off on its own because the altimeter changed and the drone was trying to maintain altitude.  This only happened after landing without shutting off motors, but it pays to be careful.
2017-5-7
Doc Larson
Kneepuck Posted at 2017-5-7 13:09
Solid advice, thank you
2017-5-7
KM5RG-Robert
Doc Larson Posted at 2017-5-7 08:41
While the motors were running or off?
What I was suggesting was let it warm up (motors off) a little more and see. I don't think the altitude will change with the motors off as it sets that at take-off (I think).
2017-5-7
DJI-Jamie
Doc Larson Posted at 2017-5-7 08:40
Just to make sure I'm on the same page, there's a discrepancy between the readings from the Go app than what's on the Autopilot app or do they both read the same values?
2017-5-8
Doc Larson
DJI-Jamie Posted at 2017-5-8 15:16
They will read the same.
2017-5-26
proimages
Flight distance : 1004731 ft
Hi having the same problem on a P4 and Android tab reporting 25' up 50 feet off, always lower never higher. I've been watching this for a couple weeks now.. almost always land in at 20 foot high or more. Caused a couple near crashes about ready to return the craft. In the year I've been flying I never noticed this much discrepancy before
2017-5-26
fansa84fe8a4
Flight distance : 3 ft
I have Autopilot too and have seen this odd altitude event where if I set it to 30 feet in a box pattern, the outward leg may be 30 feet visually, but coming back inward it climbs to maybe 50 feet.  If I allow it to continue in the box it drops to 30 feet again on the outward, but climbs again on the inward.  It's very odd.
In GO 4 I've seen it differ by 45 feet from take-off to landing, but I just chalk it up to not a military type grade aircraft.  Sometimes while flying it shows -6 feet in altitude too.
2017-6-9
ocean224
I too have had this issue since day one. Nobody seems to have a solution.  It happens in the Go 4 app, But it,doesn't seem to occur in the GS Pro app.
2017-6-9
