Mavic Camera/Gimbal Moving Slow Horizon Tilt
1030 7 2017-5-9
ProQuad
Flight distance : 20296870 ft
OK, all.  Having a weird issue with my Mavic, and I'm not sure if I should turn it in or not.
I was out for a flight the other day, turned on my RC, turned on the quad, then turned on the mini 4.  As it was warming up and waiting for the green, the camera would slowly rotate counter-clockwise.  I waited a few min. but it never corrected itself, so I turned the quad off and restarted it and that took care of it.  Now I would not post a one time issue here but this has happened about 4 times now.
Anyone else have this weird issue?  I did NOT go into the app and correct the horizon tilt because I didn't think I needed to do that.  This has never been in a crash, however, this is a "replacement" for one that I did turn in for a broken camera ribbon cable & gimbal.
ANy DJI moderators have any suggestions?  UGH, if I turn this in, it will be another full month of down time.  Thanks for all your help in advnace.
2017-5-9
dronist
Few people mentioned this before. It happened after FW .600. I did not experience it but you can also use the C1-C2 buttons to crroect it. No need to send it back. Am sure DJI is working on software update to fix the glitch!
2017-5-9
Adinfinitum
Flight distance : 603816 ft
Same here.
2017-5-9
dronist
SPEAK OF THE DEVIL...
DJI just released the new uptade.
2017-5-9
dronist
Update to .700 and verify that your issues are GONE!
2017-5-9
ProQuad
Thanks everyone.  I am in the process of updating & re-cal-ing everything then will go out for a test flight later today.  I'll get back and confirm.
2017-5-9
ProQuad
dronist Posted at 2017-5-9 07:29
dronist,  Well I took it up for about 3 battery's worth yesterday (Tues.) and I don't think I had any issues, BUT I did notice that while in the air the horizon was off just a bit.  Maybe I will recal the camera again and try it once more....dang it, guess I have to go flying again.
2017-5-10
dronist
ProQuad Posted at 2017-5-10 02:45
Man, I feel bad for you that you have to fly again...
Let us know...
2017-5-10
