Bad quality at 96fps?
1941 6 2017-5-10
fans8be934e2
Sweden
I am aware of the problem of aliasing at 1080p higher fps. It does not bother me so much because I'm just shooting as an amateur. When I search on youtube for "Mavic 96fps" I find several videos that I would definitely be happy with. But when I'm shooting 96fps, I get really bad quality. Not close to what I see that you others have managed to get. I have tested several different settings, I have tried both manual focus and auto focus. When I look at the recording in the DJI app immediately after the flight, it looks okay (it's played up at 96 fps, I think) because its normal speed, but when I transfer it to the computer, it's in 25fps? And then played in slow motion but the quality is very bad. Not blurred, but more like seeing a low resolution.
Are there any settings I might miss?
Thanks in advance.
2017-5-10
Dronoob
Flight distance : 126079 ft
The Mavic saves all 96fps recordings as 24fps and 120fps recordings as 30fps. That is why the videos are played back with a quarter of their original speed. If you want higher framerates without troubles, you can go up to 60fps.
There are quite some complains about this. But we never got a serious answer if this is a bug or an intended feature (with an explanation what the feature could be).
It is difficult to judge video quality without seeing the video. Can you upload it somewhere so that we can see it?
2017-5-10
fans8be934e2
Sweden
I can record a new video. Should I have any special settings or just record with default settings?
2017-5-11
Dronoob
fans8be934e2 Posted at 2017-5-11 00:53
I always use 4k/30fps (NTCS). If you reduce the resolution to 2.7k or 1080, the video quality will go down as the scaling is done in quite a bad way.
2017-5-11
DJI-Jamie
Flight distance : 112405 ft
Could you happen to provide a sample of what you're getting?
2017-5-11
Dronoob
DJI-Jamie Posted at 2017-5-11 16:31
Original video recorded at 1080/96: https://www.dropbox.com/s/zfkqod8nn9apbft/DJI_0636.MOV?dl=0
2017-5-12
djiuser_mUOFcX4TGFR8
I also have the same Issue, really bad quality on 96fps, its weird. Now my videos are messed up.
2020-1-25
