Nigel_
Flight distance : 388642 ft
A car charger may be a good idea if you will be using a car, amazingly that power socket is the same all around the world! Although some plugs still don't fit in some sockets.
Officially nearly all of Europe uses 230 volts AC with various styles of socket, the actual voltage varies between around 210 and 250 depending on where you are, most power adaptors/chargers will be fine with this if using a suitable socket adaptor, but check what is written on them before plugging in. |
