Hummingbird.UAV
Flight distance : 27489951 ft
Some info on the controller sticks. The Mavic controller uses new technology to sense the position of the sticks. In the old days moving the stick caused a variable resistor to rotate changing the current flow. In the Mavic controller there is a magnet at the end of the stick. Four sensors detect the strength of the magnetic field which changes as the stick is moved.
The short of it is any stray magnetic field is going to mess with this. There is a way to calibrate the sticks, check the manual. |
