Analysing Flightrecords
855 7 2017-5-17
Zimmerman 61
Flight distance : 730052 ft
Since reading the forum I have been blown away with how some oft you guys can interpret the flight records and assist individuals with locating their aircraft. Not sure if this would be a huge task but is it possible to develop some sort of "idiots guide" to analysing flight records and what steps should be followed. I have read with interest numerous posts regard Flight records but must admit it seems a little out of my depth. However I do consider myself able to learn if provided with the necessary tools and explanation.
Cheers
Zimmerman
2017-5-17
Nigel_
Flight distance : 388642 ft
Yes, the idiots guide is simple:
  • Ask the experts by starting a new thread with your question.
  • Provide the flight log via http://www.phantomhelp.com/LogViewer/upload/
  • Provide as much other accurate information as possible.
  • Sit back and wait for several different answers.
  • Wait a bit longer for the discussion to decide which answer is correct.
  • You now have your answer.
2017-5-17
Labroides
Flight distance : 9991457 ft
First learn aas much as you can about how the Phantom is programmed
Then learn as much as you can about common mistakes and their effects
Next hope the owner gives you a few clues in their description of what happened.
Look at the flight on Google Earth
Then look at the data, working your way through to find what was happening during the flight.
Identify the point (s) where things went wrong, taking into consideration things like wind, terrain, lost signal, RTH, altitude, joystick input, distance, error messages, battery level at startup  and whatever else might be a factor.
Use Google Earth to investigate terrain if that was part of the problem.
Then take another 30 minutes to write a report  if it's a complicated incident.
2017-5-17
endotherm
Flight distance : 503241 ft
Labroides Posted at 2017-5-17 04:17
...just 30 minutes!
2017-5-17
Labroides
Oops ... you're right.
That should be ... 30 mins to write it up, more if it's a complicated incident.
Some get quite complex.
2017-5-17
Phantomski
Flight distance : 14869882 ft
Lots of pple here r great and willing; just use them Personally I am surprised that those experts are not from DJI, but DJI overall does not seem great in interpreting the logs.. unless things get escalated...
2017-5-17
Zimmerman 61
Thanks all for your replies. I think I will jump in and look at my own Flat get records to start wit.
Cheers
2017-5-18
Zimmerman 61
I mean Flight records
2017-5-18
