Goggles arrived, but will not work.
12Next >
8480 51 2017-5-22
fans509b5d56
Flight distance : 122759 ft
Hi all
My goggles arrived earlier, and, so far, I could not be more disappointed.  First impressions, quite heavy, and, when they are flipped up, quite precarious.  That's probably due to my head shape.  They just do not feel "connected".  When I tighten the headstrap, it pulls the bottom of the goggles away from my face quite a bit so light can stream in.  Also, I was quite surprised that the focal distance is very close.  I do not wear glasses except for reading, so was not expecting to wear glasses with the goggles on.  I've had Fat Sharks in the past, and also own an Oculus Rift, neither requiring glasses, as they focus to infinity.  With no glasses, these goggles are a blurry mess.
The main problem, however, is they will not acivate.  I've been able to browse menus only.  It asks me to sync with the Mavic, and tells me it's successful.  It then asks me to take off, and activate the goggles from my mobile device.  No options appear on my phone at all.  If I just click to confirm it searches for a few seconds, and then tells me that the connection has failed, and I have to go through the linking process again.  Tried it 4 times now, and nothing.  The instruction book is scant, to say the least, and I have no idea where the problem lies.
2017-5-22
fans509b5d56
Currently trying to activate them via Assistant 2.  The "Activating" progress dial is just whirling around forever
2017-5-22
bunny too
Flight distance : 13442 ft
fans509b5d56 Posted at 2017-5-22 05:30
Any luck friend?
2017-5-22
fans509b5d56
Finally managed to activate it via Assistant 2.  Just need to decide whether or not to go buy some more reading glasses that are happy with the very short focal distance, or just bang it on eBay.  Really don't know why they couldn't have allowed focal adjustment, and not just IPD.
2017-5-22
fansa31537f9
Flight distance : 709134 ft
Same here. Goggles will not activate. DJI support was rubbish.
2017-5-22
Mafia16
Flight distance : 26490948 ft
Dominican Republic
You have to try activate the DJI Goggles with the Assistant 2
2017-5-22
Masemoto
Flight distance : 5137425 ft
Mafia16 Posted at 2017-5-22 11:36
Here are the steps I took:
Turned on the goggles. It prompted me to link them to my Mavic.
Turned on the Mavic and pressed the linking button. They Linked up.
Then goggles prompted me to activate so I chose mobile device.
With the Mavic still on I turned on the Mavic remote with phone plugged.  On the Mavic home screen it showed a message that the goggles were successfully activated.That was it.
2017-5-22
ShadyDealer
Flight distance : 983428 ft
Everyone else's screen 100% clear? Grrr mine has a bit of black debris towards the top left upper screen. Don't know if I should raise my concern/return?
2017-5-22
DRONE-flies-YOU
Flight distance : 1450594 ft
There is no moderator for the Goggles section. Notice how it is blank. I thought it was weird noone has chimed in from DJI. This is a new section.
2017-5-22
DJI Joe
DRONE-flies-YOU Posted at 2017-5-22 16:05
It's actually blank on all sections. The moderator indicator has been broken for a bit now. Already reported to devs.
If there are any issues, customers may find more luck in the Service section rather than in the discussion section.
2017-5-22
BlueThunder71
I've just received my Goggles. Tried them for 2 mins. Looks like they are going back. The focal range is so close that everything is a blur unless I wear reading glasses. As someone else said, the likes of the Oculus have an infinite focus so no glasses necessary.
These are completely different. £500 down the drain unless I sell them or return to DJI.
2017-5-24
rydfree41
Flight distance : 153268 ft
BlueThunder71 Posted at 2017-5-24 10:22
ah but the Oculus rifts look like crap even when focused ,LOL . A $6 pair of reading glasses puts them in perfect focus .
2017-5-24
BlueThunder71
I disagree that the Rift looks crap. However, I digress. Every other quality headset I've used from Sony HMZ gens 1, 2 and 3 to the Oculus all had infinite focus, keeping the eyes relaxed. I know a pair of reading glasses would fix the issue, but I don't need reading glasses for everyday life, using my phone etc. I suspect this issue is from a cost/space saving perspective and it is very disappointing. A bunch of folk will have to carry round glasses to use the Goggles? That is pretty poor.
2017-5-24
rydfree41
BlueThunder71 Posted at 2017-5-24 13:14
I can't stand that screen door effect on the Rifts .
If you don't need glasses to read or clearly see your cell phone when held close then there may be another issue if you need them with the Dji goggles . I do need them to see clearly but my 27 year old daughter put them on and said they were perfectly clear .
2017-5-24
BlueThunder71
My set isn't defective. It is a sign that I need reading glasses. However DJI made a decision to have the focal range too close unlike every other headset manufacturer I've tried, alas.
2017-5-24
I am the E
Just got mine activated by pushing the button on the mavic located next  to the SD Card and then it said connected. I am also having the same problem with seeing blurred images. even if I wear my glasses. I might end up returning them. Will give it another try tomorrow.
2017-5-24
DRONE-flies-YOU
BlueThunder71 Posted at 2017-5-24 15:25
They've done an incredible job with the focal range by giving it curvature like a Samsung curved 4k TV (their 1080 curved has more curvature).  Physics dictate the focal range.  Otherwise no matter what, the screen would appear the same size since you've got to keep moving it farther & farther back as you go bigger.  This is why you buy a certain size TV and place it at a relative viewing distance.
I do not use reading glasses, but I know I'm due.  I'm using mid-range glasses with these (I borrowed them) and it makes the picture perfect.  Reading glasses gave me screen door, especially with HDMI.  I'm glad I do not have to wear glasses, as the bridge of my nose with those & these goggles gets pretty irritated after 2 batteries.
2017-5-24
mfangler
Flight distance : 7359 ft
hi fans - mine arrived 2 days ago and yet again feel like a test dummy for DJI. It will not activate and as you say the focus is FAR FAR too close.  Have tried assistant with no luck and like you feeling sooooo frustrated. Please do let me know if anyone has answer.
2017-5-26
mfangler
Masemoto Posted at 2017-5-22 13:28
Wrong . This does not work. I wish it did  though as I am thoroughly HACKED off with DJI for not making this process any EASIER.
2017-5-26
mfangler
No focus option is a bad mistake. I am having to buy new specs just because of DJI poor design.
At present however I seem to be having ACTIVATION issues like other users.
Come on DJI sort yourselves out. I am fed up being a test bed for your mistakes.
Where is support when you need them!
2017-5-26
DroneFlying
Flight distance : 10774613 ft
mfangler Posted at 2017-5-26 04:47
Uninstall the version of DJI Assistant 2 that you currently have, install the latest version, and try again. You can't activate the goggles with an older version of the application.
2017-5-26
DRONE-flies-YOU
mfangler Posted at 2017-5-26 05:09
I turned on the Mavic & R/C.  Turned on goggles FOR THE FIRST TIME.  After a few prompts, it said it was ready to link.  I selected the LOWER option for the Mavic.  The goggles tell you when to push the link button on the Mavic.  DONE!  It did the linking, activating, and completed setup on its own.  Then the Mavic livefeed popped up & I crapped my pants.  EASY!
2017-5-26
yozo
Flight distance : 799944 ft
Bulgaria
Dji Go4 activation works only with Mavic. All other drones need to activate via the assistant software
2017-5-27
Capo
Flight distance : 178196 ft
Does anyone know what the actual focus distance is for the Goggles?
2017-6-1
Paul Pangrazzi
Count me as another disappointed buyer... while I can't necessarily complain about the fact that the goggles don't feel like they fit properly, I will complain that it can't be focused!  This might be a deal breaker, as I'm not keen on buying reading glasses just for this (and thereby supporting what appears to be a very poor decision on DJI's part.)
2017-6-1
fans2ce2dabf
Flight distance : 4242 ft
This is insane.  What a let down not being able to focus on the screen.  Glasses are uncomfortable and fog up easily.  Google cardboard at least focuses.  Come on DJI, serve your customers.
2017-6-1
fans5020cec9
Flight distance : 60082 ft
I just received my Goggles today and activated with no problems via the Mavic, although it did take a while. Focus was the big disappointment for me as well and I don't normally wear reading glasses. Might go get a cheap pair to see if that helps but I agree with others that this should be integral with the goggles.
2017-6-14
conprot.otenet
Flight distance : 224354 ft
Greece
same problem here have trying to activate but activation fails .Strangely ,closing and opening the assistant  it opened the firmware update and updated to latest firmware.Still no activation.
i do not have a Mavic but a P4Pro , so i have no option but to use only the Assistant.Any help?
2017-6-19
Senorpablo
Flight distance : 407323 ft
After three hours, still won't activate for me.
2017-6-19
fans9815c421
Philippines
did you tried to reinstall the DJI Assistant 2 V1.1.1 on your computer MAC/Windows? then and the app as admin if you're in windows os?
2017-6-19
Tarsicio Sañudo
Flight distance : 856890 ft
Mexico
Hello i just receive mines. I start with problems with the activation. But i erase de Assiatnce 2 and downlaod the lates one and they activated really easy. The problem is that the older version give you the chance to download and install the firmware but not the activation.  May be it can help. Sorry for my english
2017-6-23
Drmerlin
Flight distance : 2441663 ft
rydfree41 Posted at 2017-5-24 12:37
Occulus is fantastic. The suggestion that it looks crap is utter rubbish! I use Occulous and Flyinside for flight simming. It is excellent!
2017-6-26
rydfree41
Drmerlin Posted at 2017-6-26 05:16
Rubbish , your standards are simply set too low
2017-6-26
Drmerlin
rydfree41 Posted at 2017-6-26 05:27
And what product, in your opinion, does the job better right now?
2017-6-27
rydfree41
Drmerlin Posted at 2017-6-27 03:00
The fact there may not be a better product does not negate the fact the Oculus display sux .  The Dji display does far better if only it had the connectivity as the Oculus . I've looked at the oculus several times and just can't get past the display . Perhaps they are better now tough . I haven't put a pair on in about 6 months .
2017-6-27
Drmerlin
rydfree41 Posted at 2017-6-27 11:30
Yes the clarity of the DJI Goggles is great compared to the Oculus BUT do not give you anything like the same immersive experience as the Oculus. I am looking forward to 4K Oculus as soon as someone invents a graphics card and computer powerful enough to drive them. Of course the Oculus is much more comfortable to wear than the DJI Goggles....
2017-6-28
fansfe421c8a
The set up for the goggles is so aggravating! I tried linking following the prompts with mobile device, GO app.  Keeps giving me the error to make sure that the aircraft and controller are linked after the "60" second countdown.  Tried multiple times, updated everything with latest firmware.  Won't link.  Next I tried the DJI Assistant.  Yes, I downloaded latest version from DJI website.  Nothing!  I plug the googles in and nothing happens.  Called support and they were utterly worthless.  Can someone help me?
2017-7-1
fans108b0ca5
I have exactly the same problem
2017-7-6
fans108b0ca5
When I plug my Goggles in to my MacBook Pro with the latest version of DJI assistant.. I briefly see the Goggles being recognized and then they disappear.
2017-7-6
fans108b0ca5
I do exactly the same but at the point where I select to register with mobile device.. nothing happens..
I am in the house however and my Mavic does say Disconnected on the DJI Go app.. could that be it?
2017-7-6
12Next >
