Nigel_
Flight distance : 388642 ft
Flysuzu Posted at 2017-6-3 01:08
Ok - so have taken the P3A for a fly at the mine today and have taken the advice from earlier in the post. Did not calibrate the compass, left in GPS mode, and flew a little away from the ore body.
Drone flew like normal, hovered fine, and remained in control for the whole flight. Only had some screen minor screen flickering when over one of the pits but that could have been wifi interference from the network. Seems to work fine - will try closer to the ore tomorrow.
Did you check the orientation of a compass or the compass on your tablet against map north?
It's quite possible that the magnetic field of the ore is lined up with the earths magnetic field and thus there is no problem.
Stay ready to gain height and switch to atti mode if it does suddenly shoot off into a curve though. |
