DJi Googles SD card problem
12Next >
11869 41 2017-5-23
pcardon
Flight distance : 135092 ft
Hi,
Have just received today my DJi googles, and it seems that the SD card reader is failing. Following is what I tried :
• Attempting to format a SD card (have tried with 2 different cards, from 2 different brands), after confirming that I accept to loose all my files, displays "No DJi googles card Inserted" message
• Attempting to dowload a JPEG file from my Mavic, displays the message "Failed to download remote file" after few seconds
• Attempting to read the SD card coming from my Mavic displays the message  "No DJi googles card Inserted"
• Attempting to read the local storage displays either "File list empty" if a card is inserted, or "No DJi googles card Inserted" if no card is in the reader. This means that the SD card is detected …
Not sure this is a related problem : I have updated the googles firmware to the latest available version (V01.03.0700), and each time I start the DJi googles I have a "Latest version detected" message displayed …
Has anybody the same problem ? Can a DJi person take a look to this problem description ?
Thanks in advance
2017-5-23
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, were you able to activate the DJI Goggles successfully?
2017-5-23
pcardon
yes and all is working fine, except the SD card reader
2017-5-23
DJI-Jamie
pcardon Posted at 2017-5-23 11:58
Could you happen to clarify what SD card types you tried thus far?
2017-5-23
pcardon
SD cards
SD cards
Hello,
Thanks for answering me …
I used a Samsung 64 Gb EVO micto SD xc I, which I already use in my Mavic Pro without any problem …
I tried a Sandisk Extreme 16 GB HC I
I tried a Verbatim HC 8 GB
Regards
Pascal
2017-5-24
DJI-Jamie
pcardon Posted at 2017-5-24 02:14
[view_image]
Hello,
Just to clarify, are you hot swapping the SD cards? Try removing the cards and restarting the Goggles. Once that message has cleared, power cycle the Goggles with the SD card in. This is an issue that will be addressed in the next firmware.
2017-5-25
pcardon
DJI-Jamie Posted at 2017-5-25 11:38
OK,
Just tried now, first inserting the card, then Power up the Googles, then attempted to format the SD card, with no success, I received the "No Dji googles SD card inserted" message …
2017-5-26
DJI-Jamie
pcardon Posted at 2017-5-26 08:27
OK,
Was that even after power cycling with the SD card out initially?
2017-5-26
pcardon
DJI-Jamie Posted at 2017-5-26 13:25
Power cycling don't solve the problem, I'm completely unable to use the SD card  reader
2017-5-27
fans87fec950
I'm having the same issue. Sd card is not able to be formatted or read.  Firmware is up to date.
2017-5-27
fans60fb5b2a
Flight distance : 64065 ft
fans87fec950 Posted at 2017-5-27 08:33
Hi there I noticed you are having sad card issues with your goggles, I'm having the same issues could you give me any advice on how to resolve the problem regards steve
2017-5-31
fans60fb5b2a
OK,
Hi I'm having the same issues as you on dji goggles sad card reader, could you tell me if you sorted it out and if so how regards steve
2017-5-31
DJI Natalia
Flight distance : 318 ft
fans60fb5b2a Posted at 2017-5-31 14:17
Have you tried the method that Jamie mentioned above?
2017-6-1
fansfe104d13
Flight distance : 1285610 ft
I have this exact same issue. The goggles don't appear to support SD cards yet.
2017-6-1
pcardon
DJI Natalia Posted at 2017-6-1 03:25
Yes I tried Jamie's method … no way …
My SD card reader has never worked for me …
2017-6-4
Narwhal
pcardon Posted at 2017-6-4 07:38
I am having the same exact issue, and none of the fixes work.
2017-6-4
DJI Natalia
Sorry about that, I reported it to the engineers for a further evaluation, will come back to you once I hear from them, thanks.
2017-6-5
ragnar7
Iceland
I'm having the same problem, even after upgrading the firmware to the newest one today. Seems the SDI slot doesn't work at all!
2017-6-8
pcardon
DJI Natalia Posted at 2017-6-5 00:37
Thank you for your help …
2017-6-8
pcardon
Hi,
I have good news !
For the first time, I was able to use the SD card reader after DJi Googles firmware update V01.03.0800 …
I will confirm in few days, but it seems to work …
2017-6-8
DJI Natalia
pcardon Posted at 2017-6-8 09:12
Hi,
I have good news !
Thank you very much for your update, glad to hear it's working after firmware upgrading.
Keep us posted, thanks.
2017-6-8
DJI Natalia
ragnar7 Posted at 2017-6-8 03:47
It only supports FAT32 format, nut not the NTFS. And the maximum is 32GB.
Just to verify, what the type of SD card you were used for it ?
2017-6-8
ragnar7
Iceland
I use a 32gb SD card formatted by the Mavic Pro... does that not format in FAT32?
2017-6-9
ragnar7
Iceland
Well yes .. it's FAT32...
2017-6-9
neonadler
1. Please check whether the SD cards have been formated as FAT32.
2. Please upgrade the goggles to the newest firmware.
    It fixes an issue that sdcard is not recognized after hotplug.
3. If your sdcard meets all the following conditions, could you kindly help to provide your sdcard brand & specific model?
a. the sdcard is formated as FAT32
b. the sdcard storage size is not larger than 32GB
c. the sdcard is has been inserted into Goggles before it is powered on and not hotplugged.
2017-6-9
pcardon
DJI Natalia Posted at 2017-6-8 19:17
Finally, it was a short time joy … Yesterday I tried again, and again the SD card reader don't work at all … It's unable to read the SD card coming from my Mavic, it says there are no files, and If I attempt to format the SD card, I have a "No DJi googles SD card mounted" message …
My googles will definitely needs a service repair … and I can say that this didn't work from the beginning …
2017-6-10
ragnar7
Iceland
I have the exact same as Pcardon!
2017-6-11
DJI Natalia
pcardon Posted at 2017-6-10 08:48
Sorry to hear that, our R&D engineers replied you at 25#, please double check it and keep me posted, thank you.
2017-6-12
DJI Natalia
ragnar7 Posted at 2017-6-11 03:03
Sorry for the issue, please double check all the info our engineers posted at 25#, and keep me posted. Thanks.
2017-6-12
pcardon
DJI Natalia Posted at 2017-6-12 00:57
I already done all the checking :
  + Tried to format it both from my computer and from my MAVIC
  + Upgraded to V01.03.0800 firmware
  + Tried these 2 SD cards : KINGSTON 8 Gb HC I and Sandisk Extreme 16 GbHC I
  + As already said, formatted from the MAVIC. PLEASE Note (again) that formatting from the DJi Googles should work, whatever the original format is … but SD formating don't works !
+ Have tried many models from different capacities, i.e. 8 and 16 Gb
+ Have already done this test and said it in my previous comments. Whatever I do, it doesn't work !
It only worked once, just after the 0800 firmware upgrade ... and failed again, few days later
2017-6-14
DJI Natalia
pcardon Posted at 2017-6-14 08:08
Sincerely apologize for the trouble caused, sorry we failed to get it resolved remotely after all the basice troubleshooting, in that case, please send it in for evaluation, we'll take care it for you, appreciate your patience and support again!
2017-6-15
ragnar7
Iceland
So any idea when or if a firmware update will address this...? or is this maybe a hardware issue that needs to be fixed with a repair?
2017-6-21
fansbd9ceef2
Flight distance : 291821 ft
August 15, 2017
Has anyone heard of or seen a fix for this yet?
Also, on the mac in disc utilities, there is not a FAT32 format. There is ExFat and MS-DOS (Fat). I tried both of those with a 16GB card and have not been able to see anything either. The sample videos play because they are built into the goggles software, and I did a three finger tap once and got the goggles to take a screen grab. That's about it. Is there a file directory structure on the card that also needs to be followed?
2017-8-15
fansbc88d2c9
Flight distance : 16463 ft
The problem I am having is when I try to download video or photos from my aircraft to the Dji goggles sd card I get a error and the aircraft disconnects. I use a spark with my Dji goggles and both are up to date on the firmware as of 8/27/17
2017-8-27
GusBarb
Flight distance : 228727 ft
Mexico
DJI Natalia Posted at 2017-6-15 04:14
Hello Natalia, I just got my goggles with version V01.04.0100 and still have the same issue, Do you have any news about it? I've been trying with 2 SD cards, 16gb and 8gb, none woking. Thanks for the help
2017-12-5
DJI Thor
Flight distance : 13602 ft
GusBarb Posted at 2017-12-5 15:45
Hi sir, please try to format the SD card via PC, the SD card that is less than or equal to 32GB should only be formatted into the FAT32 file system. The recommended cluster size is 32KB, then plug it back to the Goggles. If it doesn't work, could you please provide me with the photo of the error message? It might be a little bit hard to shoot. Thank you for your help.
2017-12-5
fans80786199
Flight distance : 194843 ft
Thailand
Can this problem be solved? I ask for a solution to this problem. Thank sir
2021-7-7
anfre
Indonesia
hi...I'm from year 2023... and until now this problem hasn't been solved by DJI, I'm still having this problem on goggles v2, no SD issue T_T
2023-1-14
AvataUser86
Not only have I continually been having this issue- I have a major one to add to it. I recently tried to eject the card and my finger was immediately burned to the point that it blistered. I pulled the card out and it was black and charred. Seems like a safety issue.
2023-4-21
djiuser_AzokZziNms1d
Hello !
I have the exact same issue on my FPV Goggles V2 brand new out of the box.
I've tried everything already said here but still sd not detected inside Goggles V2 > Works fine inside the DJI O3 Air Unit, as well as on my friend's Goggles Integra
Did someone manage to get i work here ?
Thx
2023-5-9
12Next >
