URGENT - IPAD MONITOR IMAGE FLICKERS SINCE APP UPDATE
2488 20 2017-5-24
ReelTech Aerial
Flight distance : 460269 ft
Hi all
Updated to the newest version of the go app for my inspire 1 RAW on my ipad.
Since the update, when flying the craft the image on the screen constantly cuts in and out, going black or green.
I use the drone professionaly and have a job this coming weekend and am in a panic.
Ive tested it on my andriod phone on the latest app and the image is fine so im assuming its an issue with the latest IOS app update
ive tried multiple cables, two different ipads
is there anyway to roll the app back to the previous version?..
Thanks in advance
2017-5-24
ReelTech Aerial
UPDATE -  tested on a third ipad and same issue. Working perfectly on andriod device. Now means I will have to purchase 2 new android tablets knowing that soon the app will be fixed and ill have 4 tablets
2017-5-24
Donnie *
Flight distance : 3636782 ft
ReelTech Aerial Posted at 2017-5-24 09:46
What kind of I pad is giving you issue , If you are a professional pilot and videographer  then get the  I pad Pro with 256 gig ,GPS  and cell and you will be better off than the android .
Any of the older I pads wont work well with the latest updates , the encryption is what seems to have sent the older processors over the edge, I have seen this many times .
donnie
2017-5-24
ReelTech Aerial
Donnie * Posted at 2017-5-24 11:55
Thats what I use, 2 of them., and i'm still having the issue.  I cant see  the pros having incompatibility issues
2017-5-24
ReelTech Aerial
appreciate the response though
Tom
2017-5-24
ReelTech Aerial
sorry ignore me they are mini 4s. still cant see them having issues yet
2017-5-24
Donnie *
ReelTech Aerial Posted at 2017-5-24 12:58
There are many variables on  the I pad Mini's , they work in some areas and not others, depends on the amount of free space on the hard drive , how much clutter of 2.4 signals in the area etc.  BUT I assure you , if you get and I  pad pro with the specs I gave in the earlier e mail, you wont be disappointed.
In the meantime try this  on the Mini's to get by .
"Enable" the Hardware Decode on the go app under General Settings .
Disable the record feature and clear the Cache on the Go app.
Make sure you lower  the Image rate  on the go app ( if you can , not sure they give the option in the UK )
Make sure the IOS is up to date  and make sure you have plenty of available space .
Perhaps also lower the 4k to 1080 If this will work for your job.
The above may help for a bit , give it a try .
donnie
2017-5-25
Aerial-Inspirat
Flight distance : 597487 ft
I am experiencing the exact same problem. Cant use my Inspire for anything other than mapping.
2017-5-26
fansa84fe8a4
Flight distance : 3 ft
I'll add I have an iPad Air 2 plus cellular and noticed around version 4.0.4. of GO 4 that the image tends to break up if I do much screen touches like shutter etc.  Not much, but it is beginning to show up now.  The Air 2 might be getting long in the tooth with GO as it grows.  I'll wait for the iPad Pro 2 to appear before trying to address it.
2017-5-26
ron34238
Flight distance : 87776 ft
iPad Mini 4 and same issue. Quite annoying yet no real solution. Any further insight would be appreciated.
2017-8-11
RichJ53
Flight distance : 1837356 ft
I have seen this same issue with my iPad mini 4  The flickering happens on the home page and will not let you even tap on the correct aircraft type. I shut it down and opened the Go App on the Inspire page then restarted the remote and Inspire 1.... then it connected.
I thought this was a fluke, but now I think it is a new DJI bug created on the last update
Rich
2017-8-11
paraviz02
Same issue here. I get CPU is maxed out warning very quickly in flight, and then the image quality goes down significantly and blacks out multiple times until the flight is finished.  Prior to the recent firmwares, the image quality on the iPad mini 4 was flawless the entire flight.
Essentially the Inspire 2 becomes unusable at this point for any legitimate purposes.
2017-8-11
mancuso_inc
Flight distance : 39708 ft
Donnie * Posted at 2017-5-25 04:27
Hey Donnie, you mention lowering the image rate on the go app. I've looked around for this option and can't seem to find it, though I thought it was in the Channel menu...?
2018-1-1
Farnk666
Flight distance : 1711394 ft
There is another variable here as well.
The early versions of the Inspire 1 RCs had an integrated GPU which looked after much of the processing load in dealing with the video stream from the AC. Later versions don't have the capability and the app does the processing on the mobile device.
If you have an 'A' or 'B' RC then an older iPad mini will be fine. Later ones will need more performance from the device.
I run a Mini 2 on a 'A' series RC and it works perfectly.
2018-1-1
DTK
Flight distance : 1943159 ft
This is news. Why do they take away the GPU of RC given that every new version of FW/SW are more process intensive than previous one.
2018-1-1
Farnk666
DTK Posted at 2018-1-1 23:51
No idea, it was probably an opportunity to save production cost as the app developed.
2018-1-2
Donnie *
mancuso_inc Posted at 2018-1-1 19:47
If I did say that I misspoke , I met the Image transmission rate on the Go app itself  , it is under the HD settings and is a a sliding scale .
sorry If I mis spoke
donnie
2018-1-2
mancuso_inc
Donnie * Posted at 2018-1-2 16:31
You know, I still had the channels set on Auto, and just realized it had to be set to Custom for the scale to be visible. (I thought auto only selected the channel, not the quality of transmission as well)
2018-1-12
Donnie "Apple"
mancuso_inc Posted at 2018-1-12 14:13
Auto chooses the channels that are available , so if you did NOT  do the "hack" this would be channels 13 -20 and if you did it would auto scan between 1 -32.  Incidentally this is ONLY  for the Image transmission , the Control of the AC is through channels 13 -20  so doing the hack will not effect the control of the Aircraft . ( Just wanted to point that fun fact out to you )
But more to your point ...I am not sure what the Auto mode defaults to regarding Bit rate , you bring up a good point!  I would guess that it would be somewhere in the middle  but not sure ,  I will try to find out .
*** You are correct in the Image Bit rate will only pop up in custom mode .  The members in  UK do not get this Option at all , the only way is if they register the RC transmitter for the USA.
***When in Custom mode try channel 20, some of the real technical guys found this to be the quietest overall as it does not overlap ( or very minimally ) with wi- fi channels .  I usually go to the flying site and then look over the chart  on the Go app HD tab to find a quiet channel , given e it a minute to settle and see what comes up . I usually fly channel 20 .
Have fun and good luck
donnie
2018-1-13
Donnie "Apple"
Aerial-Inspirat Posted at 2017-5-26 06:35
Try my suggestions in the above or read my tips page top to bottom . ..
Video Transmission issues with X3 or X5 ? Try These Suggestions !
donnie
2018-1-13
mancuso_inc
Donnie "Apple" Posted at 2018-1-13 09:53
Thank Donnie, I'll give channel 20 a shot, I always selected something in the middle!
2018-3-25
