Tmygun
Flight distance : 2972497 ft
I don't know if this will be pertinent to you but Ill give you my story.
Had an iPad mini 2 Grey, which means it had a black border around the screen.
Had it out several times and it would work initially and start malfunctioning as time went on. Finally realized it was a heat issue.....AND the black border on the edge of the screen was making that issue worse.
I would cool off the iPad and it would be fine for a few minutes but then would exhibit exactly what you described above.
Ordered a hood from DJI and that would help extend the time a little, but discerned that the iPad running the app would get warm and the sun would finish the job............in addition I think the iPad mini 2 was underpowered for the job.
Ended up getting an iPad mini 4 Silver with the white border and have never had an issue since......of course the increased ability of the 4 might be contributing to a lack of issues.
Look...I can assure you that I don't drink the Apple Cool-aid........but I know heat WAS an issue for me and processing power MIGHT have been an issue for me......but what you are describing is exactly what I went through.
Hope this at least gives you a place to start.
Good Luck!
