Landing gear problem - explained
717 3 2017-5-30
gmanthegman
Russia
A little follow-up to my previous post regarding the trouble I have with the landing gear:
https://forum.dji.com/thread-96914-1-1.html
It's all about a dead motor.
A friend of mine had absolutely same problems with his I-2: landing gear stuck and it doesn't move at all.
The repair service installed a different motor from I-2 to his drone and it worked perfectly fine.
The dead motor has absolutely no visible damages, so I presume it could be "just" manufacturing deffects.
I personally hope that most of users are experiencing the software issue.
However I'm 100% positive, that my drone has a dead motor too, like many other I-2 owners.
2017-5-30
DTK
Flight distance : 1943159 ft
Is it under warranty?
2017-5-30
gmanthegman
Russia
DTK Posted at 2017-5-30 16:39
I would be mad if it's not covered under standard warranty.
A friend of mine however did not have time (and DJI Care), so it was a much quicker and sufficient way to solve the problem, described above.
I'm just going to send mine to DJI and wait...
2017-5-30
DTK
All is good then. Hopefully, it does not take you too long. You need to keep on the case otherwise, it may drag on months.
2017-5-31
