P4P+ controller firmware downgrade ??
4026 9 2017-6-10
Nil73
Mexico
Anyone know if its possible to downgrade the controller firmware on the Phantom 4 Pro+ ?? The new firmware has made my controller useless for the work that I use it for.
2017-6-10
racer888
Flight distance : 99970 ft
Can you explain why? (I also have the P4P+ and use it commercially)
2017-6-10
Nil73
Mexico
On the HD menu, the HDMI OSD display toggle button has been removed.. I use the drone form live broadcast via HDMI. Now you can remove the OSD display, making the new firmware useless to me.  The controller is down gradable, I did it earlier..
2017-6-10
Amerigo
Nevose with new upgrade ke impossibile to work
2017-6-10
Fabio Mora
Flight distance : 1730722 ft
Brazil
Nil73 Posted at 2017-6-10 10:21
I'm with this same problem
2017-6-10
Fabio Mora
Brazil
2017-6-10
picky
Flight distance : 279 ft
Philippines
Yes you can downgrade the controller to the previous version.  Just put the bin file of the previous version on a mini sd and put in the controller. Make sure you not connected to the web. turn the wifi off. Go to update and select local update and reinstall. all should be back to how it was.
2017-6-11
WC-Pilot
Flight distance : 148258 ft
picky Posted at 2017-6-11 03:24
where can you get all of the previous RC firmware files from?  They are NOT on the DJI Site ... at least not that I can find.
2017-6-16
shan
Flight distance : 17211 ft
Check this link comment #265http://www.phantompilots.com/thr ... 0602.116642/page-14
2017-6-16
picky
WC-Pilot Posted at 2017-6-16 16:25
The aircraft files are easy as once you connect the quad to your pc and launch dj assistant 2 you can see the previous firmware and option to downgrade. The rc controller you need to download from the bin file.
If you did not download to your pc at the time of release then it will be difficult to down grade the rc.
2017-6-17
