not working... red light in solid state :(
1141 3 2017-6-10
fans56ec7b62
Philippines
My Osmo getting weird,
- When I try turn on the OSMO, I got twice Blink Green light and suddenly change into Solid Red on the Right Indicator, while Left Indicator shows Solid Green.
- Wait about 30s, then Osmo turn off automatically
I'm trying to fix with
- Plug the micro-USB to PC, hold Trigger + Record + Power Switch, Format the SD card, copy OSMO_FW_V01.06.02.10.bin into root folder of SD card.
- Disconnect and Turn off the Osmo
- Hold Trigger + Record + Power Switch, got Blink Red-and-Green on the Right Indicator. 5seconds later got Blink Red-and-Green on the Left Indicator - seems like firmware being update
- Wait about 5 minutes, got sounds D.D and the Osmo turn off automatically (seems like upgrade failure sounds).
- Turn on again still got same issue "twice Blink Green light and suddenly change into Solid Red on the Right Indicator, while Left Indicator shows Solid Green."
Already test with different battery (primary and secondary) and different SD Card (16GB and 32GB)
2017-6-10
fans2ef03170
Morocco
same issue for me My osmo was working fine I stored it for 2 month an now it start for 5sec and turned off with a solid red led.
2017-6-11
fans2ef03170
Morocco
that there is a BETA firmware that will resolve this issue!! can any one provide it for us
2017-6-11
fans3df8321b
India
I have also same problem
Please help
2017-6-21
