PROBLEMS GAINS A3+LB2
2158 28 2017-6-12
Juan carlos3
Flight distance : 31768 ft
I have 2 A3 + LB2
1ª  GRYPHON 1000 OCTO X
      Hekules III
      T-motor U5
      Propellers KDE 15 "triple
      A3 + LB2
      X 5
2ª DROIDWORS 400
     T-motor Air40
     T-motor 3506-25
     propellers 12"
    A3 + LB2
DJI ASSISTANT V1.1.1
DJI GO V3.1.11
A3  VERSION 1.7.0.5
LB2 VERSION 1.2.10
I've got that you fly well,rising nearly full the gains and the sensitivity and lowering the yaw
I've played with the gains, the exp ,sensibilities ,and the result is the same in both devices.When I do the yawl dron moves making circle in that direction, when loose the drone returns to exit site
The truth is that not is to play already,but it starts has seem to Mikrokopter programming
but to MIKROKOPTER I make it work.The A3 nooooooooo
2017-6-12
Juan carlos3
Forgive my English translator
What happens, is it normall?
I've tried with s-bus and the same
Am I doing something wrong?
Please, tell me something, I'm desperate
I didn't know that was so complicated,and I have since August of last year
2017-6-14
WiSi-Testpilot
It is difficult for me to understand your problem. Probably your x y z settings of the GPS tower are wrong. Please post a few pictures of your drones, a video of the behavior and screenshots of the assistant2.
Best regards,
Wilhelm
2017-6-14
Juan carlos3
dron
dron
2017-6-15
Juan carlos3
2017-6-15
Juan carlos3
2017-6-15
Juan carlos3
Here is the link to the video
https://www.dropbox.com/s/7qs7to ... O-00000002.mp4?dl=0
Moving only the YAW,The drone makes movement of rotation and translation,as if the station was a mixture
2017-6-15
WiSi-Testpilot
I can not see a mistake. The X Y Z values seem ok. ( I have MC Z also zero.)
Did you calibrate the compass? (copter danze)
Best regards,
Wilhelm
2017-6-15
Juan carlos3
Measuring tools it always before you fly
the problem is the YAW
that also moves
The Gryphon is equal
2017-6-15
Juan carlos3
2017-6-15
WiSi-Testpilot
I think you have not calibrated the compass.
https://dl.djicdn.com/downloads/ ... manual_V1.41_EN.pdf
Follow the instructions on the A3 Manual page 19.
2017-6-15
Juan carlos3
In the manual puts nose down
DJI GO is nose up
2017-6-15
WiSi-Testpilot
Nose down is correct!
2017-6-15
Juan carlos3
As always made it
2017-6-15
WiSi-Testpilot
Did you test the ATTI mode? In this mode GPS is off.
On the second copter you may remove the aluminium housing.
I am back later in the evening.
Best regards,
Wilhelm
2017-6-15
Juan carlos3
In mode ATTI is equal but more exaggerated
It does the same thing with the housing than without housing
I downloaded the garden to calibrate and the result is the same
2017-6-15
c53steeler
Hi!  I had a question on how the A3 works.  I currently have the A2, and it needs a 2.4GHz datalink.  The A3 is not compatible with that, but does not seem to have any replacement for it.  I am not running the D-RTK, and I do not have the Datalink Pro.  So how was the 2.4GHz datalink replaced?  I am using the Lightbridge 2.  I am assuming the information that the 2.4GHz was communicating is somehow going through the Lightbridge 2, but I do not understand how that can be happening.  Any clarification would be appreciated!  Thanks!
2017-6-15
Juan carlos3
I think that this solved
The problem was not my
an hour ago they have released an update ,I have just set it up, but I think it works
tomorrow I'll try more
2017-6-15
Juan carlos3
Are you flying well with the update?
Before it was evident he was not flying well
2017-6-17
WiSi-Testpilot
Did you solve the problem? Is 1.7.1.5 ok?
I am still on 1.7.0.0.
If possible show a video.
Best regards,
Wilhelm
2017-6-17
Juan carlos3
I did not update it,Flies well,But in stationary !!!!!!!!!!!!!!
The gains to 100%,  And it costs him to stay
2017-6-18
Juan carlos3
https://www.dropbox.com/s/kpo39ks6rs1lqfk/Archivo%2022-6-17%2020%2051%2013.mov?dl=0
I rescued it at the end
2017-6-22
Juan carlos3
Even with the last updating the YAW doesn't work.
When I press the YAW several times the function get blocked and sometimes it rotates on its axis
I really think that DJI launches its updating without checking them previously
2017-6-24
WiSi-Testpilot
Please show a video of the copter with the problem.
Thank you.
Best regards,
Wilhelm
2017-6-24
Juan carlos3
Watch the above video,only played the YAW,Watch as it moves
2017-6-24
Juan carlos3
FW 1.7.0.5  It doesn't work
FW 1.7.1.5  It doesn't work
Someone is working with them?
2017-6-24
Juan carlos3
anyone with 1.7.1.5 version?
that such works?
2017-6-26
Juan carlos3
Today this
2017-7-2
Juan carlos3
And the problems continue
Does not solve the drift yaw
It seems that DJI considered it a normal thing
2017-7-10
