Firmware issues V01.04.0602
1851 7 2017-6-12
Eric Oosterbeek
Flight distance : 76847 ft
Hi all,
Like many I had huge problems with the HF downstream of my P4P after installing the latest firmware V01.04.0602 of June 8th 2017. The HF downsream is not connecting well causing your screen to glitch and the Status LED to blink fast from red, green and yellow without an audible signal.
The solution that worked for me was to downgrade back to V01.03.0509 of April 12th 2017. I used DJI Assistant 2 to do so.
All HF feed works normally again and the blinking Status LED is a steady green again.
Hope this will solve the many questions.
2017-6-12
Punchbuggy
Flight distance : 483166 ft
Did you update the RC too (to 1.4.1)? It's required to get the link successfully reconnected after the P4P update to .604
2017-6-12
Eric Oosterbeek
Punchbuggy Posted at 2017-6-12 17:47
Yup. Then also I don't see the need yet to get the latest version. Seeing all the complaints, it should not even have been distributed as a pre-pre-pre-alpha
2017-6-12
Punchbuggy
OK, then sadly I have nothing I can suggest further, Eric. After methodically working through the process (starting with cold update of P4P using Assistant 2, updating the RC via phone wifi after GO told me I needed to, and manually re-connecting the link), it all worked for me. Took it for the ultimate test on the weekend (mentioned in another thread) and all good - apart from needing a change of underwear afterwards.
Sorry to hear your experience hasn't been as successful as mine. I'm amazed at the variance of success. I'm suspecting solar flares, or perhaps people should start sacrificing chickens to the Great DJI God prior to starting the update process?
2017-6-12
Cetacean
Flight distance : 2528264 ft
Eric Oosterbeek Posted at 2017-6-12 17:56
Aloha Eric,
     Sounds like your device is getting overwhelmed by the new upgrades and firmware.  What device are you using?  DJI GO 4 works best with a multi-processor and 2 GB RAM.
     Also are you disabling all background operations and downloads?  Uninstall or disable all apps that have nothing to do with DJI.
     Hope this helps!
Aloha and Drone On!
2017-6-12
Antonio76
Flight distance : 144403 ft
Denmark
Punchbuggy Posted at 2017-6-12 18:09
LOL, Punchbuggy!  But it was Socrates who told his friends   "don't forget to sacrifice a rooster to Asklepios..."   I'm sure we are not at THAT stage...
2017-6-13
Punchbuggy
Antonio76 Posted at 2017-6-13 01:50
hehe but yeah, after reading of all the problems people are reporting with the latest P4P firmware, are you sure of that?
2017-6-13
Antonio76
Denmark
Punchbuggy Posted at 2017-6-13 16:40
Absolutely!  Especially in the morning, after i have taken my first cup of coffee and my daily dose of painkillers, I am quite an optimist
2017-6-13
