gandrei
Flight distance : 27730 ft
Switzerland
Hi and thanks for your feedback, I also respect your opinion, but I think you are wrong for the following reasons:
1. You assume the crash is here: 08m 40s -5.2 ft 700 ft Mode Mode changed to Atti
That is not correct, looking over altitude that is already under water. The crash happened earlier
2. b 08m 35s 8.9 ft 695 ft Warning Warning:Subject lost. Searching ...
c 08m 36s 5.6 ft 701 ft Mode Mode changed to GPS_Atti
In one second there is a loss of altitude of 3.3 ft, the drone was already falling at this point, rotating in a vertigo which was not controllable. the altitude was small, reaction time probably around 2-3 seconds.
3. the crash actually happened within one second before the warning at 08:35. At the moment when propellers hit the cliffs, that resulted in a sudden change of direction and therefore the camera could not track the subject as it was probably switched orientation, and thus the warning message from 08m 35s
4. Flight time Altitude Home Distance Compass Turn Rate Per 0.1s
A 08m 35s 8.9 ft 695 ft 30.7
My understanding is that it was spinning at this point already
I am not an experienced drone pilot, I won't claim that, and can accept a good explanation too, but chances are that my 4 points prove the collision happened before you say I had controls.
Cheers |
